| | Help with BSOD Was reinstalling Vista Home Premium last night when I recevied the following BSOD STOP: 0X00000124 (0X0000000000000000,0XFFFFFA800192CA00,0X00000000,B6002000,0X000000000000011A) Now this occurs right at the beginning of installing immediately upon hitting install now. Have tested all memory and hard drives and they are fine.. Have reseated all memory, and check all connections and they are correct.. Specs are ASUS M2N-E motherboard with an Amd dual core 6000. Two Sata drives, along with 2 Sata DVD-CD's. Any ideas ? |
| | Re: Help with BSOD Clean the dvd with a soft dry cloth and try again. "Mark Stonecipher" <markstonecipher@xxxxxx> wrote in message news:4233D4ED-B87A-4823-A352-B8A6D92C73A9@xxxxxx Quote: > Was reinstalling Vista Home Premium last night when I recevied the > following BSOD STOP: 0X00000124 > (0X0000000000000000,0XFFFFFA800192CA00,0X00000000,B6002000,0X000000000000011A) > > Now this occurs right at the beginning of installing immediately upon > hitting install now. Have tested all memory and hard drives and they are > fine.. > Have reseated all memory, and check all connections and they are correct.. > Specs are ASUS M2N-E motherboard with an Amd dual core 6000. Two Sata > drives, along with 2 Sata DVD-CD's. Any ideas ? > |
| | Re: Help with BSOD Never even thougt of that. Could that really be causing it. Any idea on that stop code. THanks\ "Colin Barnhorst" <c.barnhorst@xxxxxx> wrote in message news:05832B29-DB20-4672-B781-DA09720B1D83@xxxxxx Quote: > Clean the dvd with a soft dry cloth and try again. > > "Mark Stonecipher" <markstonecipher@xxxxxx> wrote in message > news:4233D4ED-B87A-4823-A352-B8A6D92C73A9@xxxxxx Quote: >> Was reinstalling Vista Home Premium last night when I recevied the >> following BSOD STOP: 0X00000124 >> (0X0000000000000000,0XFFFFFA800192CA00,0X00000000,B6002000,0X000000000000011A) >> >> Now this occurs right at the beginning of installing immediately upon >> hitting install now. Have tested all memory and hard drives and they >> are fine.. >> Have reseated all memory, and check all connections and they are >> correct.. >> Specs are ASUS M2N-E motherboard with an Amd dual core 6000. Two Sata >> drives, along with 2 Sata DVD-CD's. Any ideas ? >> |
| | Re: Help with BSOD Making sure the media is clean is computer 101 stuff. Lint on optical media can and does cause bad reads. If you are using the nVidia firewall and Active Armor uninstall them. There are discussions on the net about this stop code and the nVidia stuff. I can't verify but that is what pops up a lot. The other item I am seeing is that this stop code is caused by audio devices. The workaround given is: 1. Go to the BIOS by pressing [DEL] during POST. 2. Go to Advanced Chipset Features. 3. Go to CPU Configuration 4. Select C1E Enhanced Halt State and set it to Disabled 5. Press [F10] to save the changes and exit. Hope one of those solutions solves your issue. "_Mark_" <ms2@xxxxxx> wrote in message news:%23SkV$HIeIHA.5548@xxxxxx Quote: > Never even thougt of that. Could that really be causing it. Any idea on > that stop code. THanks\ > > "Colin Barnhorst" <c.barnhorst@xxxxxx> wrote in message > news:05832B29-DB20-4672-B781-DA09720B1D83@xxxxxx Quote: >> Clean the dvd with a soft dry cloth and try again. >> >> "Mark Stonecipher" <markstonecipher@xxxxxx> wrote in message >> news:4233D4ED-B87A-4823-A352-B8A6D92C73A9@xxxxxx Quote: >>> Was reinstalling Vista Home Premium last night when I recevied the >>> following BSOD STOP: 0X00000124 >>> (0X0000000000000000,0XFFFFFA800192CA00,0X00000000,B6002000,0X000000000000011A) >>> >>> Now this occurs right at the beginning of installing immediately upon >>> hitting install now. Have tested all memory and hard drives and they >>> are fine.. >>> Have reseated all memory, and check all connections and they are >>> correct.. >>> Specs are ASUS M2N-E motherboard with an Amd dual core 6000. Two Sata >>> drives, along with 2 Sata DVD-CD's. Any ideas ? >>> > |
| BSOD - Debugging a BSOD in Vista | Tutorials | |||
| Bsod | General Discussion | |||
| BSOD????? | Vista performance & maintenance | |||
| BSOD | Vista hardware & devices | |||
| Vista BSOD, am unable to shutdown without BSOD, logoff OK | Vista General | |||
