| | Problem with sound Hi, I have Vista 64 bits with ASUS P5K motherboard with Realtek HD Audio. I have a problem with sound, the sound has a strange noise and crashes. In addition, when I use stereo configuration, for the left speaker it sounds ok but for the right it's a lot lower and with more noise. I have checked the speakers and the cables and are ok so I don't know if it's a windows/driver problem or a hardware problem. Can anybody help me? Some ideas?? Thank you very much. |
| | Re: Problem with sound Boot into Safe Mode - go to Device Manager and DELETE/REMOVE everything under SOUND - reboot as normal and select search for new drivers. This will ensure your drivers are installed correctly even if they are the same ones. "Aleix" <Aleix@xxxxxx> wrote in message news:958792FC-5BA8-42CB-8A8D-4BCAEC53647D@xxxxxx Quote: > Hi, I have Vista 64 bits with ASUS P5K motherboard with Realtek HD Audio. > I > have a problem with sound, the sound has a strange noise and crashes. In > addition, when I use stereo configuration, for the left speaker it sounds > ok > but for the right it's a lot lower and with more noise. > > I have checked the speakers and the cables and are ok so I don't know if > it's a windows/driver problem or a hardware problem. Can anybody help me? > Some ideas?? > > Thank you very much. |
| sound problem | Sound & Audio | |||
| Sound Problem | Vista General | |||
| Sound problem | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| 5.1 sound problem with Realtek ACL655 on board sound | Vista hardware & devices | |||
