1.    29 Feb 2008 #1
    Hume Guest
    Encountered a critical problem and will restart in one minute
    Hi there, quite a long winded explanation below, please bare with me!
    Had my laptop for a while now, always ran smoothly but now this message keep
    appearing:
    'Windows has encountered a critical problem and will restart automatically
    in one minute. Please save your work now.'
    At first i thought it was a problem with msn messenger, so i stopped it
    starting up using MsConfig. But the message is still coming up. It comes up
    when i try to log on using itunes, another message appears with it saying:
    'We could not complete your iTunes store request. A secure network
    connection could not be established.
    Make sure SSL 3.0 or TLS 1.0 is enabled in the Internet Options panel, then
    try again.'
    I'm pretty sure they are enabled, i checked a while ago. The message also
    comes up when i try to login to 4oD, 4 on Demand. It seems that everytime i
    try making a connection with a server the PC can't take it.
    I've read in another post about a guy who got the same message, he said he
    solved it by:
    'I have talked again with Microsoft support today and we have found the
    culprit.
    The problem is an ActiveX control used by some Banks in Brazil
    (Service for G-Buster Browser Defense - C:\PROGRA~1\GbPlugin
    \GbpSv.exe).
    This control has become corrupted and thus affect the Windows Vista
    cryptographic system which causes a problem that generates that error
    message and make the system restart in one minute.
    As there is no solution at this moment the recommended workaround was
    to log in Safe Mode and disable this ActiveX control.
    After doing this the error has disappeared and the system get back to
    normal state.'
    I don't know how to disable anything using safe mode as I am not so computer
    literate. It would be very helpful if someone could tell me a solution to me
    problem or give me a run through of how to use safe mode, etc
    thank you very much
    Lachie
  2.    07 Mar 2008 #2
    Diego Guest
    RE: Encountered a critical problem and will restart in one minute
    I have the same problem here. Not sure how to disable the Activex Controls
    and especially this one from the Bank.
    Hope to get rif of this relly soon or I'll install the old and good Debian
    Linux on this lap.
  3.    07 Mar 2008 #3
    Diego Guest
    Hey Lachie! Your question was really important to me. I was having the ame
    problem. Here was an Activex from Banco do Brasil.
    I got it!
    First you need to start in safe mode, pressing F8 after booting your system.
    Than you open Internet Explorer 7, go to "Tools", "Manage Addons". Choose
    from the box "Downloaded Activex Controls" and delete the one you think is
    causing problem. Than you can reboot and have fun.
    You woon't be able to acess the bank using Vista, but finally the message
    and the booting was solved.
Critical Error, Restart in One minute, Unable to Safemode
Hi all, My father is having desktop eMachine with Windows vista 32 bit home. AMD dual core some kind of from eMachine. There was some problem that...
General Discussion
Setup controller has encountered a problem during install
Setup controller has encountered a problem during install. Please review the log files for further information on the error. anThis is the message...
Software
.NET Runtime Optimization Service has encountered a problem
I just installed PowerShell 2.0 on Windows XP. When I run it, I get a popup that says ".NET Runtime Optimization Service has encountered a problem...
PowerShell
windows live messenger has encountered a problem
messenger 8.5 works perfectley. When i install 2009 version i can not sign in i do not get any error messages it just comes up "windows live...
Live Messenger
VMware NTVDM.EXE has encountered a problem
VMware NTVDM.EXE has encountered a problem Has anyone encountered this in either VirtualPC 2004 or 2007?
Virtual PC
Every now and then while in Windows mail I get the message: Windows mail has encountered a problem and has to shut down. it usually happens when I am...
Vista mail
Windows Live Mail Has Encountered a Problem
Hi there, Just downloaded and installed all the applications from the Windows Live Hotmail site today. This WLM won't open. I don't know what...
Live Mail
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
