| | Problems with USB Whenever I try to connect an USB device to any of my ports, it reads it, but it does not open it in autoplay.. then i try to manually open it in my computer but when i click on it it says it needs format, and when i want to format it, it says that it was unable to format it... this happens with my USB memory (1gb sony), my ipod, and it also happens on my card reader with a sony memory stick.. anyone know how to solve this?? |
| Windows 7 RC | Re: Problems with USB Whenever I try to connect an USB device to any of my ports, it reads it, but it does not open it in autoplay.. then i try to manually open it in my computer but when i click on it it says it needs format, and when i want to format it, it says that it was unable to format it... this happens with my USB memory (1gb sony), my ipod, and it also happens on my card reader with a sony memory stick.. anyone know how to solve this?? I've read there is a bug in Vista that doesn't load the USB drivers correctly. When installing them specify c:/windows/system32 for the driver location. It has helped many people with similar issues. Please let us know if it works for you. |
| Big vista problems need help icon/background/graphics/personalise problems | Vista performance & maintenance | |||
| laptop start up problems and problems in general | General Discussion | |||
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
