Vista - Enable Advanced Performance for the Hard Drive
Old 03-12-2008   #1 (permalink)
home premium vista (64bit)
hello all
after clicking on "Policies" and makeing sure the dot is in
"Optimize for Performance", i put the check mark in "Enable write caching on
the disk", and "Enable advanced performance" i click OK.
but when i go back in again the check marks are removed?
anyone no how i can fix this. i have 3 w/d harddrives 2 are raid
thanks mike
Old 03-25-2008   #2 (permalink)
deendinesh
Re: Enable Advanced Performance for the Hard Drive
On Mar 13, 1:17*am, scrooge <scrooge.366...@xxxxxx-mx.forums.net> wrote:
Quote:
> hello all
> caching on
> thanks mike
> scrooge
This problem persists in windows 2003 server also
even after enabling the advance performance option and clicking ok
the option is automatically getting disabled ..
i dont find any fix in internet so far..
probalby registry setting might help in case of both vista and 2k3
server
Solved Poor Hard Drive Performance? General Discussion
difference between 'Enable write cache ' & 'Enable advanced' Vista performance & maintenance
advanced hard drive power managment Vista hardware & devices
Enable advanced performance Vista performance & maintenance
Hard Drive Performance Vista hardware & devices
