| Vista Home Premium | DVD-CD Drive not working...HELP! Hello, I have a Pioneer DVD-RW DVR K17A ATA Device dvd/cd drive that is not working on my Toshiba laptop. When I check out the drives properties through my device settings, the device status reads as below: "This device cannot start. (Code 10) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available." After I check for solutions, nothing happens. I cannot play dvd's or cds or any programs that use this drive...needless to say is very frustrating! Does anyone have any advice on how to fix? Thanks! |
| | Re: DVD-CD Drive not working...HELP! Hi, Follow the steps here (method 2): http://support.microsoft.com/kb/314060 The fix in Vista is the same as in XP. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Wallyhockey17" <Wallyhockey17.36c4w4@xxxxxx-mx.forums.net> wrote in message news:Wallyhockey17.36c4w4@xxxxxx-mx.forums.net... Quote: > > Hello, > > I have a Pioneer DVD-RW DVR K17A ATA Device dvd/cd drive that is not > working on my Toshiba laptop. When I check out the drives properties > through my device settings, the device status reads as below: > > "This device cannot start. (Code 10) > Click 'Check for solutions' to send data about this device to Microsoft > and to see if there is a solution available." > > After I check for solutions, nothing happens. I cannot play dvd's or > cds or any programs that use this drive...needless to say is very > frustrating! Does anyone have any advice on how to fix? > > Thanks! > > > -- > Wallyhockey17 |
| | Re: DVD-CD Drive not working...HELP! Coincidentally, my DVD/CD drive on my Sony Vaio wasn't working and I clicked on this message last night - and did what Rick suggested and it worked great! I was able to use my DVD/CD drive again and burned some pictures. I just tried it again and the drive isn't working - again. Same Code 10. Any suggestions other than that for me? Thanks, Karen "Rick Rogers" wrote: Quote: > Hi, > > Follow the steps here (method 2): > http://support.microsoft.com/kb/314060 > > The fix in Vista is the same as in XP. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Wallyhockey17" <Wallyhockey17.36c4w4@xxxxxx-mx.forums.net> wrote in message > news:Wallyhockey17.36c4w4@xxxxxx-mx.forums.net... Quote: > > > > Hello, > > > > I have a Pioneer DVD-RW DVR K17A ATA Device dvd/cd drive that is not > > working on my Toshiba laptop. When I check out the drives properties > > through my device settings, the device status reads as below: > > > > "This device cannot start. (Code 10) > > Click 'Check for solutions' to send data about this device to Microsoft > > and to see if there is a solution available." > > > > After I check for solutions, nothing happens. I cannot play dvd's or > > cds or any programs that use this drive...needless to say is very > > frustrating! Does anyone have any advice on how to fix? > > > > Thanks! > > > > > > -- > > Wallyhockey17 > |
| | RE: DVD-CD Drive not working...HELP! "Wallyhockey17" wrote: Quote: > > Hello, > > I have a Pioneer DVD-RW DVR K17A ATA Device dvd/cd drive that is not > working on my Toshiba laptop. When I check out the drives properties > through my device settings, the device status reads as below: > > "This device cannot start. (Code 10) > Click 'Check for solutions' to send data about this device to Microsoft > and to see if there is a solution available." > > After I check for solutions, nothing happens. I cannot play dvd's or > cds or any programs that use this drive...needless to say is very > frustrating! Does anyone have any advice on how to fix? > > Thanks! > > > -- > Wallyhockey17 > |
| Vista 32bit SP1 | Re: DVD-CD Drive not working...HELP! go into device manager & try to update the driver for the drive. If that fails then uninstall the drive software & then restart the system. It would pick up the default software. You can also try to go into registry & delete the upper & lower filter's in the following registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Hope this helps ! |
| Optical DVD drive quits working and external DVD drive not accessible | Vista hardware & devices | |||
| cd drive not working | Vista hardware & devices | |||
| My CD drive is not working | Vista installation & setup | |||
| DVD drive not working | Vista hardware & devices | |||
| CD drive not working please help | Vista hardware & devices | |||
