Vista Tutorial - DVD RW / CD drive wont read anything
Old 03-19-2008   #1 (permalink)
shaun
Guest
Hope someone can help. I have an Advent 7113 laptop and the DVD / CD drive
has stopped reading anything. I have no evidence in device manager that
there is a problem (i.e. no symbols) and the drive also seems to be making
noises when trying to read.
Is there a software issue or update that I can download . . . please help!!!
Many thanks for any replies.
Shaun
Old 03-19-2008   #2 (permalink)
Malke
Guest
Re: DVD RW / CD drive wont read anything
shaun wrote:
Quote:
> Hi,
> drive
> help!!!
As a quick test to see if the drive has died, try using a bootable CD/DVD
such as your Vista DVD (if you have a full retail copy), an XP install CD,
or a rescue CD such as Knoppix. You may need to change the boot order in
the BIOS to optical drive first if it isn't set that way already.
Accessing the BIOS
http://michaelstevenstech.com/bios_manufacturer.htm
http://www.uktsupport.co.uk/reference/biosp.htm
http://www.computerhope.com/issues/ch000235.htm
If the computer will not boot from a known-working, known-bootable CD then
the drive itself has probably died. This is not uncommon, particularly on
laptops. In that case, contact the laptop mftr.'s tech support for
repair/replacement.
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
My disk drive just wont read my game. General Discussion
CD Drive Wont Read Any Discs Vista hardware & devices
dvd drive wont read legit vista dvd General Discussion
READ THIS IF YOU CANNOT GET DRIVE TO READ DISK TO FIX VISTA ERROR! Vista hardware & devices
My dvd-rw drive wont read disks in vista rc1 Vista hardware & devices
