Vista - hp f2105 monitor and ati radeon x600
Old 08-23-2006   #1 (permalink)
=?Utf-8?B?QiBCYXJsZXk=?=
When I upgraded to the new monitor, the drivers would not recognize the
higher resolutions. I even tried installing the hp .inf drivers for the
monitor and was still stuck at a max of 1024x768 which sucks for a wide
screen monitor.
I did a clean install and the higher res showed up using the default generic
drivers for vista.
When I installed ace excalibur from ati, I was bumped back down to 1024.
Hence, the problem is with the ati drivers and not microsoft vista.
And if you want the higher resoloutions that support wide screen, you need
to go with the generic drivers and monitor def files.
ATI Radeon X600 All-In-Wonder Vista hardware & devices
ATI RADEON MOBILTY X600 Vista hardware & devices
hp f2105 and ati x600 video card Vista hardware & devices
Radeon x600 crash Vista hardware & devices
HP F2105 Wide Flat Panel Monitor Vista hardware & devices
