Vista - Sidebar Help
Old 03-25-2008   #1 (permalink)
David
Sidebar Help
My wireless meter in sidebar says not connected, any help on how to make it
work. I know I'm connected, if it was disconnected I could not send this
post. Thanks
Old 03-25-2008   #2 (permalink)
Dustin Harper
Re: Sidebar Help
It may be bad programming on the gadget. There are several wireless status
gadgets available. You might try another one and see if that gives the
results you want.
Dustin Harper
dharper@xxxxxx
http://www.vistarip.com | Vista Resource & Information Page
"David" <droac@xxxxxx> wrote in message
news:0C4D8FDA-53EA-4258-83AF-E03B1AF91E7D@xxxxxx
> it work. I know I'm connected, if it was disconnected I could not send
> this post. Thanks
Old 03-25-2008   #3 (permalink)
Windows 7 RC
Re: Sidebar Help
Quote  Quote: Originally Posted by David View Post
post. Thanks
There are many gadgets that do about the same thing. Click on add new gadgets, and find another wireless meter from a different author.
Old 06-11-2008   #4 (permalink)
Eric
RE: Sidebar Help
I am in the same boat. Recently noticed that my gadget that detects wireless
networks says "disconnected" when it is not. I make sure the IP address is
correct and tried several versions with no luck. I recently installed Norton
2008 Anti-virus and not sure if this has something to do with it. Thanks!
> post. Thanks
Sidebar Vista General
Help with SideBar ^_^ Vista General
Sidebar General Discussion
Google sidebar vs. Windows Vista sidebar Vista General
Theme your sidebar: Windows Sidebar Styler Vista General
