| Guest | very slow hard drive write speed I have an internal Seagate SATA drive that has a good read speed and a terrible write speed. If I write small files to the drive, Windows reports that the transfer rate is less than 1MB/sec. Large files have a high speed of about 13MB/sec. I have enabled write caching and advanced performance in the hardware tab. I don't think that my antivirus is the problem, because the drive's read speed is great. The Windows Experience Index rates my hard drive at 5.5, but I feel that the drive is the slowest part of the system. I see on websites that hard drives generally have write speeds that are 40MB/sec and higher. Does anyone have a suggestion about how to increase the write speed of the drive? |
| Guest | Re: very slow hard drive write speed Observed speeds are normally slower since they include the time for the drive to physically seek to the location to be written to before the actual transfer from the drives cache to its physical platters can occur. If there is any other disk activity taking place the drives heads may need to reseek to the proper location on each transfer. A small file obviously will always include at least one seek since the heads will never be at the location that the small file is to be written at. "sigmund" <sigmund@xxxxxx> wrote in message news:01044C47-7CC9-49DA-A72F-CC4763C42EB2@xxxxxx Quote: >I have an internal Seagate SATA drive that has a good read speed and a > terrible write speed. If I write small files to the drive, Windows reports > that the transfer rate is less than 1MB/sec. Large files have a high speed > of > about 13MB/sec. I have enabled write caching and advanced performance in > the > hardware tab. I don't think that my antivirus is the problem, because the > drive's read speed is great. > > The Windows Experience Index rates my hard drive at 5.5, but I feel that > the > drive is the slowest part of the system. > > I see on websites that hard drives generally have write speeds that are > 40MB/sec and higher. > > Does anyone have a suggestion about how to increase the write speed of the > drive? |
| Guest | Re: very slow hard drive write speed First, be careful comparing speeds. Some sites/utilities are reporting megaBITS per second (these would generally be the drive manufacturer sites where they want to put on big numbers to evoke big responses) but Windows and many other measurement tools report megaBYTES per second where the total speed would be 1/8th of the speed reported in megaBITS per second. Second, copying files with Explorer is the most inefficient way to do so and will always report a slower speed than the maximum possible speed. That's why drive speed tests use direct reads/writes to the drive to rate speed rather than file copies. Finally, yes, the hard drive is the slowest part of your computer (with the potential exception of a CD/DVD drive) and always will be. It's been that way since day 1 of Windows computing because the hard drive is indeed the slowest I/O device you use every day. You can wring a little more performance out of the hard drive system by using faster drives (SATA II or SCSI drives) or by getting drives with a faster RPM speed or a larger cache - but in the end we're talking about small fractions of a second improvement for large fractions of your paycheck. :-) -- Richard G. Harper [MVP Shell/User] rgharper@xxxxxx * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ "sigmund" <sigmund@xxxxxx> wrote in message news:01044C47-7CC9-49DA-A72F-CC4763C42EB2@xxxxxx Quote: >I have an internal Seagate SATA drive that has a good read speed and a > terrible write speed. If I write small files to the drive, Windows reports > that the transfer rate is less than 1MB/sec. Large files have a high speed > of > about 13MB/sec. I have enabled write caching and advanced performance in > the > hardware tab. I don't think that my antivirus is the problem, because the > drive's read speed is great. > > The Windows Experience Index rates my hard drive at 5.5, but I feel that > the > drive is the slowest part of the system. > > I see on websites that hard drives generally have write speeds that are > 40MB/sec and higher. > > Does anyone have a suggestion about how to increase the write speed of the > drive? |
| Hard Drive is Write Protected? | Vista General | |||
| Hard drive speed boosts | Tutorials | |||
| USB Hard Drive Write Protect Error | Vista hardware & devices | |||
| Hard drive write protected | Vista General | |||
| Why is my hard drive actubg as thour it is write-protected? | Vista General | |||
