Vista - PRODUCT KEY FOR MICROSIFT OFFICE 2000 SMALL BUSINESS
Old 04-09-2008   #11 (permalink)
Jon Pope
Re: PRODUCT KEY FOR MICROSIFT OFFICE 2000 SMALL BUSINESS
YES IT SHOWS THE 25 numbered keys
"Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote in message
news:ezfYXvnmIHA.4196@xxxxxx
Quote:
> "Jon Pope" <mrjonpope@xxxxxx> wrote in message
> news5A29247-9420-48CA-BC79-B269E081DA1D@xxxxxx
Quote:
>> WELL I JUST CHECKED MINE THE PRODUCT KEY WAS THERE WITH THE BELARC SCAN
>> news:uNXZjFjmIHA.1680@xxxxxx
>>> news:81B7584A-9239-413F-9B7A-DCEEC6BE2358@xxxxxx
>>>> well if the computer is up and running u can ran www.belarc.com and it
>>>> gives u all ino on computer and product keys
>>>> news:OQ$VvjimIHA.2304@xxxxxx
>>>>> "rde" <rde@xxxxxx> wrote in message
>>>>> news:B7842090-B548-4C00-8D69-5D79E7B2E898@xxxxxx
>>>>>>I have lost my product key; is there any possibility of recovering it?
>>>>> Unless you can find the original packaging, I doubt it. The MS Office
>>>>> 2000 key code is not stored on the computer. The best you will find on
>>>>> the computer is the product ID which will not enable you to re-install
>>>>> it...
>>>>> Mike Hall - MVP
>>>>> How to construct a good post..
>>>>> http://dts-l.com/goodpost.htm
>>>>> How to use the Microsoft Product Support Newsgroups..
>>>>> http://support.microsoft.com/default...help&style=toc
>>>>> Mike's Window - My Blog..
>>>>> http://msmvps.com/blogs/mikehall/default.aspx
>>> Except for MS Office 2000 which does NOT store the key code on the
>>> computer...
>>> Mike Hall - MVP
> Are you sure that it is the key code and not just the product ID?
> Does it show 5 blocks of 5 characters, or does it appear differently?
> Mike Hall - MVP
Old 04-13-2008   #12 (permalink)
Home premium 32 bit, SP1
Quote  Quote: Originally Posted by rde View Post
Hello, everyone. This is strange. Has anyone turned the computer upside down and look at the bottom panel? I found mine there right under the upc codes. It's a series of 5 sets, each of which has 5 numbers or symbols or combination of both. Mine is a Dell though. Maybe it's different than other makes.
Old 04-13-2008   #13 (permalink)
Colin Barnhorst
That's probably the product code for Windows. The OP is asking about
Office.
"t-4-2" <t-4-2.37tlw0@xxxxxx-mx.forums.net> wrote in message
news:t-4-2.37tlw0@xxxxxx-mx.forums.net...
Quote:
> down and look at the bottom panel? I found my there right under the upc
> other makes.
> t-4-2
Old 04-13-2008   #14 (permalink)
Quote  Quote: Originally Posted by Colin Barnhorst View Post
Office.
> other makes.
> t-4-2
Thank you. Silly me, never have enough patience to read everything.
Microsoft Teams Up With CompUSA to Deliver Windows Vista Business and Microsoft Office Small Business 2007 Early to Small Businesses Purchasing Five or More Licenses Vista News
