Vista Tutorial - PRODUCT KEY FOR MICROSIFT OFFICE 2000 SMALL BUSINESS
Old 04-08-2008   #1 (permalink)
rde
Guest
I have lost my product key; is there any possibility of recovering it?
Old 04-08-2008   #2 (permalink)
Carey Frisch [MVP]
Guest
Re: PRODUCT KEY FOR MICROSIFT OFFICE 2000 SMALL BUSINESS
Recover it from where???
Carey Frisch
Microsoft MVP
Windows Desktop Experience -
Windows System & Performance
Old 04-08-2008   #3 (permalink)
RJB
Guest
Contact Microsoft, I'm sure they can assist you..
RJB
"rde" <rde@xxxxxx> wrote in message
news:B7842090-B548-4C00-8D69-5D79E7B2E898@xxxxxx
Old 04-09-2008   #4 (permalink)
Colin Barnhorst
Guest
If it is installed on your computer you can use Keyfinder to retrieve it.
If it is not installed anywhere then you need to contact MS.
Old 04-09-2008   #5 (permalink)
Mike Hall - MVP
Guest
Unless you can find the original packaging, I doubt it. The MS Office 2000
key code is not stored on the computer. The best you will find on the
computer is the product ID which will not enable you to re-install it...
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default...help&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
Old 04-09-2008   #6 (permalink)
Jon Pope
Guest
well if the computer is up and running u can ran www.belarc.com and it
gives u all ino on computer and product keys
"Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote in message
news:OQ$VvjimIHA.2304@xxxxxx
> Mike Hall - MVP
Old 04-09-2008   #7 (permalink)
Mike Hall - MVP
Guest
"Jon Pope" <mrjonpope@xxxxxx> wrote in message
news:81B7584A-9239-413F-9B7A-DCEEC6BE2358@xxxxxx
>> 2000 key code is not stored on the computer. The best you will find on
>> the computer is the product ID which will not enable you to re-install
>> it...
>> Mike Hall - MVP
Except for MS Office 2000 which does NOT store the key code on the
computer...
Mike Hall - MVP
Old 04-09-2008   #8 (permalink)
Jon Pope
Guest
WELL I JUST CHECKED MINE THE PRODUCT KEY WAS THERE WITH THE BELARC SCAN
news:uNXZjFjmIHA.1680@xxxxxx
>>> it...
>>> Mike Hall - MVP
> computer...
> Mike Hall - MVP
Old 04-09-2008   #9 (permalink)
Mike Hall - MVP
Guest
news5A29247-9420-48CA-BC79-B269E081DA1D@xxxxxx
>>>> it...
>>>> Mike Hall - MVP
>> computer...
>> Mike Hall - MVP
Are you sure that it is the key code and not just the product ID?
Does it show 5 blocks of 5 characters, or does it appear differently?
Mike Hall - MVP
Old 04-09-2008   #10 (permalink)
FeMaster
Guest
news:ezfYXvnmIHA.4196@xxxxxx
>>>>> it...
>>>>> Mike Hall - MVP
>>> computer...
>>> Mike Hall - MVP
I've always heard that it was Office '97 that nothing could retrieve the key
for... I no longer have Office 2000 installed, so I can't verify the other
posters claim. Of course, Office '97 was easy to just "create" a key for by
using a bunch of 1's and randomly trying other numbers in one of the
positions (5th position maybe?).
Microsoft Teams Up With CompUSA to Deliver Windows Vista Business and Microsoft Office Small Business 2007 Early to Small Businesses Purchasing Five or More Licenses Vista News
