| | keyboard problems Im running vista home pemium on a dell xps 410 and everything was working fine until i installed the new windows updates (4/9) and shutdown. When i first tried to turn it back on it was just a black screen, the diagnostic lights showed a faulty memory module and my owners manual suggested uninstalling the ram one at a time and reinstalling to test it. I took one out and restarted and it loaded fine, I put the other back in and this time it loaded fine. I go to log in and my keyboard(usb) doesnt work. I tried it in all other ports and it still doesnt work. I tried my other usb devices in the same ports and they work fine. I went out and bought another keyboard and it has the same problem. Both keboards work before start up but not after. Any advice would be much appreciated ty. |
| Keyboard Problems | Vista performance & maintenance | |||
| Problems with keyboard | General Discussion | |||
| Keyboard Problems | Vista hardware & devices | |||
| Keyboard problems | Vista General | |||
| Keyboard problems (again) | Vista hardware & devices | |||
