Vista - Vista SP1: USB port and usb readyboost flashdrive problem.
Old 04-15-2008   #1 (permalink)
GT
OS: Vista SP1
I wake up my computer from sleep and notification area showed a unknown USB
device driver installing but after that notification i receive another
balloon notification that the unknown usb device malfunction. that usb
flashdrive is my readyboost which is connected full time, work fine and vista
detect it fine. So I unplug the usb flashdrive and insert it on the same usb
port the usb is working fine again.
Old 04-15-2008   #2 (permalink)
Richard G. Harper
Re: Vista SP1: USB port and usb readyboost flashdrive problem.
From time to time this happens. It's a USB thing. Windows XP did (and
does) it also.
"GT" <GT@xxxxxx> wrote in message
news:F6EE209C-BA81-45D0-B98E-2AD7C00EA8F1@xxxxxx
Quote:
> OS: Vista SP1
> USB
> vista
> usb
Old 04-16-2008   #3 (permalink)
Wonderman
Same Here. I'd like to leave the stick in the back of the PC and forget it
but it needs to be re-inserted at every start up. I'm going to try a
Memory Stick ( seems fast enough ) and see if it also happens with that too.
Quote:
> OS: Vista SP1
> USB
> vista
> usb
How to install Vista with only USB Flashdrive? Vista installation & setup
Vista on 32GB flashdrive? Vista installation & setup
readyboost flashdrive on the usb socket? Vista hardware & devices
readyboost flashdrive on the usb socket? Vista General
Vista 64 Readyboost problem Vista General
