DVD problem after vista sp1 installation
  1. #1
    Dark_Shadow Guest
    Yesterday i installed SP1 on my vista ultimate x64 via microsoft update after
    that all was ok expect for the dvd drive it cannot read dvd's anymore cd's
    are ok though i figured that this is a problem that began after the
    installation of sp1 cause before it was ok and my dvd drive is making some
    noice sometimes just like when i insert a disk in it. anyone knows what could
    the problem be?
  2. #2
    John Barnes Guest
    Re: DVD problem after vista sp1 installation
    Are you using any added software besides native Vista? Have you tried
    installing codec's again. Are you talking about reading, writing or both.
    "Dark_Shadow" <Dark_Shadow@xxxxxx> wrote in message
    news:F21F090F-C9BE-439E-A4DA-FAFE037DF68B@xxxxxx
    > after
    > could
    > the problem be?
  3. #3
    SwiftImmortal_1 Guest
    RE: DVD problem after vista sp1 installation
    you could try a firmware update for your drive...shot in the dark but the manufacturer may be aware of the problem and MAY have released a fw update for it.
    Post Originated from http://www.VistaForums.com Vista Support Forums
  4. #4
    Dark_Shadow Guest
    I did a firmware update to the latest available and nothing changed. Well i
    have uninstalled SP1 yesterday just to see if the problem would fix and it
    didnt so it looks like that it isnt an SP1 problem after all it just happened
    to occur at the same time probably my drive reached its limit or something.
    Thanks for the help though
DVD problem after vista sp1 installation problems?
Vista installation problem. Riven16 General Discussion 0 08 Nov 2009
Vista Installation Problem so1id General Discussion 7 14 Feb 2009
Vista Installation problem Bcrawfordil Vista General 1 01 Dec 2008
Problem with installation Vista x64 Haubentaucher General Discussion 3 03 Apr 2008
problem with vista installation =?Utf-8?B?SGFucyBN?= Vista installation & setup 1 18 Sep 2006
