Vista - Wireless adapter keeps re-enabling
Old 04-20-2008   #1 (permalink)
mlefebvre
I got a new Dell Vostro computer running Vista Home Premium. The computer
came with a wireless network adapter but I am hardwired with an ethernet
connection. I keep getting the message that my computer has 2 IP addresses
and I should disable one card. When I disable the wireless adapter, the
message goes away for a day or so and then comes back because something has
re-enabled the wireless adapter. Is there a way to keep the wireless adapter
disabled?
Old 04-20-2008   #2 (permalink)
DL
Re: Wireless adapter keeps re-enabling
If your wireless is on the motherboard, you should be able to disable in the
bios.
If its a card, simply remove it
"mlefebvre" <mlefebvre@xxxxxx> wrote in message
news:2B2C113C-EF25-41B5-A2F4-97E350395244@xxxxxx
> addresses
> has
> adapter
> disabled?
Old 04-20-2008   #3 (permalink)
mlefebvre
Sure that would work, but every now and then, I need to use it, and I was
hoping to not have to remove it. Why can't it be disabled and stay disabled
until I re-enable it? Is this some Vista quirk?
"DL" wrote:
> bios.
> > addresses
> > has
> > adapter
> > disabled?
Old 04-20-2008   #4 (permalink)
DL
I cannot answer as to why it occasionally gets enabled;
I have a winxp pc with two ethernet connections, one is disabled & has never
been enabled unless I enable it.
I also have a Vostro with ethernet & wireless card, only the wireless is
enabled, the ethernet has never enable itself
news:6B6D0AEA-A3F3-4C17-87FC-F8B349774436@xxxxxx
> disabled
> "DL" wrote:
>> the
>> bios.
>> >computer
>> > ethernet
>> > addresses
>> > the
>> > has
>> > adapter
>> > disabled?
help with network (usb wireless adapter or wireless router) Network & Sharing
Vista Supported Wireless USB Adapter / Wireless PCI Card Vista General
Looking for a wireless adapter on x64 Network & Sharing
USB wireless adapter Vista hardware & devices
Enabling Wireless on notebooks Vista networking & sharing
