Vista Tutorial - my keyboard! what the heck is wrong?
Old 04-20-2008   #1 (permalink)
katiakitty
Guest
my latop keyboard has suddenly decided that it won't do what its told (if
you're wondering, i'm using the onscreen one.) instead of typing qwertyuiop
asdfghjkl zxcvbnm as it is meant to, it types qwerty456*asdfgh123zxcvbn0. its
not like numbrs have been swapped for the letters, either. the 5 is still a
5, the 0 a 0 - except now, the m key also types 0.
what can i do? my dad's gonna kill me! can ANYONE help?
Old 04-20-2008   #2 (permalink)
Mike Hall - MVP
Guest
Re: my keyboard! what the heck is wrong?
"katiakitty" <katiakitty@xxxxxx> wrote in message
news:075A50FC-A207-4BC5-89E3-D2500A51E1F5@xxxxxx
> qwertyuiop
> its
> a
Try knocking the NUMLOCK off..
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default...help&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
Old 04-20-2008   #3 (permalink)
Richard G. Harper
Guest
Hit either Shift + Numlock (hold down the Shift key, then hit the Numlock
key) or Fn + Numlock (hold down the Fn key, then hit the Numlock key)
according to which laptop model and make you own one should do the trick.
Richard G. Harper [MVP Shell/User] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
> qwertyuiop
> its
> a
Wrong Keyboard Characters Microsoft Office
Some keys on keyboard print the wrong symbol... Vista General
Belkin wireless keyboard - am I doing somthing wrong? Drivers
DOS program uses the wrong keyboard in Vista Software
Wrong Keyboard layout!!! Vista General
