| | Vista - battery plugged in, not charging |
| 04-21-2008 | #1 (permalink) |
| | battery plugged in, not charging I am currently using a laptop that is approx one year old - it's a toshiba tecra A6. It belonged to a friend and I have only received it recently, so I do not know its history. When I hover above the 'power plan' icon on the bottom toolbar, it says "0% available, (plugged in, not charging)" and, accordingly, cannot run the computer on battery power. Is this definitely a problem with the computer's battery, despite it being only one year old? -- jennifer b |
| My System Specs |
| 04-21-2008 | #2 (permalink) |
| | Re: battery plugged in, not charging jennifer b wrote: Quote: > I am currently using a laptop that is approx one year old - it's a toshiba > tecra A6. It belonged to a friend and I have only received it recently, so > I do not know its history. When I hover above the 'power plan' icon on the > bottom toolbar, it says "0% available, (plugged in, not charging)" and, > accordingly, cannot run the computer on battery power. Is this definitely > a problem with the computer's battery, despite it being only one year old? 1. The laptop's battery 2. The laptop's AC adapter 3. The charger component on the laptop's motherboard Contact Toshiba tech support for repair/replacement. Malke -- MS-MVP Elephant Boy Computers www.elephantboycomputers.com Don't Panic! |
| My System Specs |
| 04-25-2008 | #3 (permalink) |
| | RE: battery plugged in, not charging I am having the same problem (less than 1yr) at 47% I just got my 5th tooth out! |
| My System Specs |
| 07-04-2008 | #4 (permalink) |
| | Re: battery plugged in, not charging So would this also be true if it does charge as long as the lid is down? Toshiba laptop as well. Seems like it might be a setting in Windows that when it is open, don't charge but closed charge?? "Malke" wrote: Quote: > jennifer b wrote: > Quote: > > I am currently using a laptop that is approx one year old - it's a toshiba > > tecra A6. It belonged to a friend and I have only received it recently, so > > I do not know its history. When I hover above the 'power plan' icon on the > > bottom toolbar, it says "0% available, (plugged in, not charging)" and, > > accordingly, cannot run the computer on battery power. Is this definitely > > a problem with the computer's battery, despite it being only one year old? > It could be a problem with: > > 1. The laptop's battery > 2. The laptop's AC adapter > 3. The charger component on the laptop's motherboard > > Contact Toshiba tech support for repair/replacement. > > Malke > -- > MS-MVP > Elephant Boy Computers > www.elephantboycomputers.com > Don't Panic! > |
| My System Specs |
| 04-25-2009 | #5 (permalink) |
| | Re: battery plugged in, not charging I just had that exact same problem. I was stuck at 11% and I would unplug and plug back in. So, I did what I had to do: mess with my precious laptop ;_; Just kidding. I went to the HP site or http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01174488&lc=en&dlc=en&cc=us&product=3806991&os=2100&rule=6701〈=en My battery is now charging. As I type, it went from 11% to 32% and it is plugged in and charging. Says so. So! I hope this solves your problem too. Downloading BIOS files are overrated....Kidding. For easy access, I'll just use the ol' copy paste method.
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging. |
| My System Specs |
| 03-15-2010 | #6 (permalink) |
| | Re: battery plugged in, not charging For easy access, I'll just use the ol' copy paste method. Quote:
| My System Specs |
| 05-15-2010 | #7 (permalink) |
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging. With the laptop on and AC power cord plugged in, remove the battery (you may have to gently tilt the laptop up or on its side), then use the device manager to uninstall the drivers (as originally instructed). Wait about 30 seconds to 1 minute. Replace the battery, and return the laptop to an upright position. Use the device manager to scan for new hardware and reinstall the drivers (as originally instructed). After completing these step my battery tray icon indicated Battery Fully Charged 100% |
| My System Specs |
| Similar Threads for: battery plugged in, not charging | ||||
| Plugged In, Not Charging Battery | Vista hardware & devices | |||
| Battery plugged in, not charging | Vista hardware & devices | |||
PLEASE HELP! Plugged in, not charging? | General Discussion | |||
| 98% Plugged in, not charging. | General Discussion | |||
| Battery and Charging | Vista performance & maintenance | |||
