Windows Defender will show the list (type "defender" in Start/Search and
choose Software Explorer under Tools) and the programs you disabled are on
the Startup tab on the System Configuration Utility (msconfig). As the KB
describes, the idea is to enable programs one by one and reboot until the
problem returns. That will identify the culprit. At that point you can
look for updates for the culprit or leave it disabled (or uninstall it).
"Vanokat" <Vanokat@xxxxxx> wrote in message
news:EE0A5CD3-FD4D-45A9-A3F9-1E63B589362E@xxxxxx
> Hi Colin - OK I am sitting here listening to music - quite loudly and with
> no
> problems what so ever after I did the clean boot thing. Only trouble is I
> have yet to determine which program is the cause. Half my issue is I am
> stuck
> on Windows ME. I had my old computer for 6 years or so. Having lots of
> trouble getting used to Vista. Where can I locate a list like I had for ME
> that tells me what I have to have running. There is alot of stuff running
> (Thanks to my 3 teenage sons) I do not know what is what.
> Thanks for your help and time.
> Kat
> "Colin Barnhorst" wrote:
>> Do a clean boot and see if the problem persists. That will rule out a
>> third
>> party program causing the issue.
>> http://support.microsoft.com/kb/331796
>> news:4916E476-C6E1-4CF3-B7D7-2671743E9FB3@xxxxxx
>> > OK Under system type it says - 32 bit OS
>> > I DL the Realtek driver from the link you provided - it actually helped
>> > somewhat but still cracks and breaks up when I open a program.
>> >> It will tell you on the system properties page under "System Type" if
>> >> you
>> >> are using VHP x64. Right click on Computer and choose Properties.
>> >> news:C677E8CC-4300-47BD-B847-E5D711FD2AFA@xxxxxx
>> >> > Don't know 86 or 64
>> >> > System Info says... Windows Vista Home Premium
>> >> > Version: Multiprocessor Free 6.0.6000
>> >> > Will check out link. Thanks
>> >> >> What edition of Vista and is it x86 or x64?
>> >> >> Cal Bear reports in the next thread that new software came out
>> >> >> today:
>> >> >> http://www.realtek.com.tw/downloads/...&GetDown=false
>> >> >> Get it from your computer or motherboard manufacturer if you can or
>> >> >> use
>> >> >> the
>> >> >> link provided here.
>> >> >> Post back on the results.
>> >> >> news:8B41D00E-9E9F-4AD5-A54E-4CBE61E6EE8B@xxxxxx
>> >> >> > Gee that was easy enough - I knew that but forgot...
>> >> >> > Its Realtek Kigh Def. audio
>> >> >> >> Look in the device manager. As usual in Vista, just click on
>> >> >> >> the
>> >> >> >> Start
>> >> >> >> Orb
>> >> >> >> and type "device manager" in Start/Search and hit Enter. Look
>> >> >> >> down
>> >> >> >> the
>> >> >> >> list
>> >> >> >> to "Sound, video and game controller" and expand (click the
>> >> >> >> plus).
>> >> >> >> If
>> >> >> >> you
>> >> >> >> right click on the device name and choose properties you can get
>> >> >> >> further
>> >> >> >> details. Post back with the info.
>> >> >> >> news:0F1397AA-8C39-4AD7-97A1-A7F24C8CF9A8@xxxxxx
>> >> >> >> >> You need to fill us in on what computer, operating system,
>> >> >> >> >> and
>> >> >> >> >> sound
>> >> >> >> >> card
>> >> >> >> >> you are using.
>> >> >> >> >> message
>> >> >> >> >> news:6EA23171-E19F-4180-980B-7A41C3D12AB2@xxxxxx
>> >> >> >> >> >I am having problems with the sound on Vista. Music plays
>> >> >> >> >> >fine
>> >> >> >> >> >until
>> >> >> >> >> >I
>> >> >> >> >> >open
>> >> >> >> >> > anything else. If anything is loading music is severely
>> >> >> >> >> > distorted. I
>> >> >> >> >> > have
>> >> >> >> >> > updated eveything there is. I cannot listen to any music on
>> >> >> >> >> > Myspace
>> >> >> >> >> > or
>> >> >> >> >> > watch
>> >> >> >> >> > any videos on Youtube...HELP!
>> >> >> >> >> I am using a HP desktop with Vista
>> >> >> >> > How do I locate what kind of sound card??
