Vista - Monitor settings
Old 04-26-2008   #1 (permalink)
Tackleberry
Monitor settings
I have a Toshiba laptop, when I recently disconnected the projector from it,
the computer did not turn off the presentation settings, so my monitor is
stuck on some kind of magnification-like setting that I've only seen when the
projector was connected. I used the Windows Mobility Center and tried to
turn it off manually, but that did not work.
Any other suggestions?
User Settings Disappearing; Monitor Settings Unstable; Desktop Search Overtakes System; Laptops Unusable Vista General
HELP! Monitor Settings Issues: Can't Alter the Monitor Settings... Vista hardware & devices
Monitor settings Vista hardware & devices
which monitor to use under display settings? Vista General
Multiple Monitor Settings Vista General
