| | Washed out screen when on battery power I have a Dell B130 Inspiron Laptop. the laptop screen works fine when on charger. When I go to battery power the screen becomes washed out, colors are not correct and hardly readable. This is a new problem. I have the laptop set for automatic update. Has anybody else experienced this problem? -- Retired Tom |
| | Re: Washed out screen when on battery power About what percentage charged does the battery appear to be when on battery power? Does it appear washed out immediatly when you switch or does it degrade over time? How old about is the laptop/battery? "Tom" <Tom@discussions.microsoft.com> wrote in message news:9B04F457-A766-4E83-86A5-598D62321BE3@microsoft.com... >I have a Dell B130 Inspiron Laptop. the laptop screen works fine when on > charger. When I go to battery power the screen becomes washed out, colors > are > not correct and hardly readable. This is a new problem. I have the laptop > set > for automatic update. Has anybody else experienced this problem? > -- > Retired Tom |
| Alter (auto) Power settings when plugged in or on Battery Power? | Vista performance & maintenance | |||
| Backlight doesn't work under battery power | Vista performance & maintenance | |||
| should i use battery or mains power? | Vista General | |||
| Battery Power | Vista General | |||
| Battery power-RC2 | Vista General | |||
