| Guest | Intel Turbo Memory Driver problem -?? My hp Pavillion dv2000 autmoatically shut down unexpectedly TWICE in the last half hour, a search by Windows to identify the problem told me it was the "Intel Turbo memory Driver" (iaStor.sys) and I could go to the Intel Corporation website for more info - do I need to dl another driver? I don't even know what this thing is... |
| Guest | RE: Intel Turbo Memory Driver problem -?? I have an HP dv6000 running Vista Home, and this problem continues to recur, even after downloading the iaStor.sys update. I hesitate to call HP support, since I don't have time for the usual run around. Good luck, and I'll keep you posted if/when I solve it. "jandarfish" wrote: Quote: > My hp Pavillion dv2000 autmoatically shut down unexpectedly TWICE in the last > half hour, a search by Windows to identify the problem told me it was the > "Intel Turbo memory Driver" (iaStor.sys) and I could go to the Intel > Corporation website for more info - do I need to dl another driver? I don't > even know what this thing is... |
| Guest | RE: Intel Turbo Memory Driver problem -?? Does your system shut down often? Are you worried about damaging anything? (motherboard got wrecked in our last desktop, tech said probably from too many improper shutdowns) "CaptainSC59" wrote: Quote: > > I have an HP dv6000 running Vista Home, and this problem continues to recur, > even after downloading the iaStor.sys update. I hesitate to call HP support, > since I don't have time for the usual run around. Good luck, and I'll keep > you posted if/when I solve it. > > "jandarfish" wrote: > Quote: > > My hp Pavillion dv2000 autmoatically shut down unexpectedly TWICE in the last > > half hour, a search by Windows to identify the problem told me it was the > > "Intel Turbo memory Driver" (iaStor.sys) and I could go to the Intel > > Corporation website for more info - do I need to dl another driver? I don't > > even know what this thing is... |
| Guest | RE: Intel Turbo Memory Driver problem -?? Once is often enough. It happens about twice per week. My system faults, and the computer reboots. So, any unsaved work is gone. This Vista installation has a way of losing large chunks of memory, and I wonder if it's related to this Intel driver. I'm skeptical about your motherboard failure. I find it hard to believe it has anything to do with it. Improper shutdowns used to impact disk integrity though. "jandarfish" wrote: Quote: > Does your system shut down often? Are you worried about damaging anything? > (motherboard got wrecked in our last desktop, tech said probably from too > many improper shutdowns) > > "CaptainSC59" wrote: > Quote: > > > > I have an HP dv6000 running Vista Home, and this problem continues to recur, > > even after downloading the iaStor.sys update. I hesitate to call HP support, > > since I don't have time for the usual run around. Good luck, and I'll keep > > you posted if/when I solve it. > > > > "jandarfish" wrote: > > Quote: > > > My hp Pavillion dv2000 autmoatically shut down unexpectedly TWICE in the last > > > half hour, a search by Windows to identify the problem told me it was the > > > "Intel Turbo memory Driver" (iaStor.sys) and I could go to the Intel > > > Corporation website for more info - do I need to dl another driver? I don't > > > even know what this thing is... |
| Guest | RE: Intel Turbo Memory Driver problem -?? I have an HP dv6650us and I have vista Home on it and at the beginning of June my computer shut down unexpectedly I didn't think to check the problem report because it didn't show up the first time and so after the second time I checked the report and it said it was a problem with the device intel turbo memory drive. I even downloaded the update and it still happens. Hmm which is wierd because it usually happens when I am running the HP health check scan as well as having windows media player running or doing something else while the scan is going, odd because I was able to do that in the past and nothing happened just kind of got slow but that was ok until this month then it started acting up. any ideas because I have contacted HP support and I am just having them get me in touch with a case manager and see if they can replace my computer because as far as I am concerned this is a defective product for to be doing this and it is not even a year old yet. "CaptainSC59" wrote: Quote: > > I have an HP dv6000 running Vista Home, and this problem continues to recur, > even after downloading the iaStor.sys update. I hesitate to call HP support, > since I don't have time for the usual run around. Good luck, and I'll keep > you posted if/when I solve it. > > "jandarfish" wrote: > Quote: > > My hp Pavillion dv2000 autmoatically shut down unexpectedly TWICE in the last > > half hour, a search by Windows to identify the problem told me it was the > > "Intel Turbo memory Driver" (iaStor.sys) and I could go to the Intel > > Corporation website for more info - do I need to dl another driver? I don't > > even know what this thing is... |
| | #6 (permalink) |
| Guest | Intel Turbo Memory Driver Problem Did you ever happen to resolve the problem? I'm experiencing similar difficulties where the PC just freezes approx every 30 minutes. Sometimes, after approx. 2 minutes, the PC will recover and function again, other times the system will completely shut down and return a blue screen with error information. My PC (an Acer Aspire 6920) is merely 8 weeks old and has had this problem since day one. Acer of course refuses to accept any blame for this problem... |
| | #7 (permalink) |
| Guest | RE: Intel Turbo Memory Driver Problem "Nick Rust" wrote: Quote: > Did you ever happen to resolve the problem? I'm experiencing similar difficulties where the PC just freezes approx every 30 minutes. Sometimes, after approx. 2 minutes, the PC will recover and function again, other times the system will completely shut down and return a blue screen with error information. My PC (an Acer Aspire 6920) is merely 8 weeks old and has had this problem since day one. Acer of course refuses to accept any blame for this problem... > all kind of tests and I found that the problem is in the software. Read lots of posts on different sites and found out that the reason is in the turbo memory or in the intel controller or in the video driver. Try to update all those drivers nut the problem still exist. I installed a vista without a sp1 and my laptop was working until the vista decided that this is very important driver and install it automatic. so pls. if you find a solution post a resolution here. Regards, Milen |
| | #8 (permalink) |
| Guest | RE: Intel Turbo Memory Driver problem -?? I have been experiencing same issue with Blue screen and downloaded Intel driver as suggested by Windows - which oes not work. HP have a solution on their help site using a diferent version of Intel driver - it works!! https://accountservices.msn.com/Emai...=1033&urlnum=0 "jandarfish" wrote: Quote: > My hp Pavillion dv2000 autmoatically shut down unexpectedly TWICE in the last > half hour, a search by Windows to identify the problem told me it was the > "Intel Turbo memory Driver" (iaStor.sys) and I could go to the Intel > Corporation website for more info - do I need to dl another driver? I don't > even know what this thing is... |
| | #9 (permalink) |
| Guest | Re: Intel Turbo Memory Driver problem -?? I have the same problem but with a toshiba satellite P200, I tried your link but it is no longer available. Do you have the soft on your computer that maybe you can send me by email ? Thank you so much Louise louisy_fr@xxxxxx peterk;3867535 Wrote: Quote: > I have been experiencing same issue with Blue screen and downloaded > Intel > driver as suggested by Windows - which oes not work. HP have a solution > on > their help site using a diferent version of Intel driver - it works!! > > https://accountservices.msn.com/Emai...=1033&urlnum=0 -- louisay_fr ------------------------------------------------------------------------ louisay_fr's Profile: http://forums.techarena.in/members/louisay_fr.htm View this thread: http://forums.techarena.in/vista-har...ces/962989.htm http://forums.techarena.in |
| Intel Turbo Memory will not function | General Discussion | |||
| Any trick to installing a driver on a dead OS? (Turbo Memory probl | Vista hardware & devices | |||
| Intel Turbo Memory Card: This device cannot start. Code 10 | Vista hardware & devices | |||
| Readyboost vs intel turbo memory 1gb | Vista hardware & devices | |||
| Intel Turbo Memory | Vista General | |||
