br> br> |
| | Thread Tools | Display Modes |
| Guest
Posts: n/a
| After reinstalling Vista, cannot use Backup wizard to restore files ON SUNDAY MARCH 2ND I DECIDED TO REINSTALL VISTA HOME PREMIUM BECAUSE I COULDN'T GET WINDOWS MEDIA CENTER TO WORK. AFTERWARDS, WHEN I PLUGGED IN MY SEAGATE EXTERNAL HARD DRIVE AND TRIED TO USE THE BACKUP WIZARD I SAW THIS MESSAGE: -\"THE DISK CONTAINING THE BACKUP IS NOT ACCESSIBLE. PLEASE MAKE SURE IT IS TURNED ON AND CONNECTED TO THE COMPUTER.\" -I PANICKED AT FIRST BECAUSE I THOUGHT THIS MEANT THAT I WOULD NOT BE ABLE TO ACCESS THE FILES ON MY SEAGATE, BUT I REMEMBERED THAT I COULD GO THE LONG WAY BY GOING THROUGH WINDOWS EXPLORER AND CLICKING ON FOLDER AFTER FOLDER AFTER FOLDER, ETC. I WOULD RATHER NOT HAVE TO DO THIS, ESPECIALLY SINCE ALL I'M LOOKING FOR IS JUST -ONE -FOLDER! CAN ANYONE OFFER ANY SUGGESTIONS ON WHAT TO DO, OR WILL I JUST HAVE TO ACCEPT THAT I'LL HAVE TO CLICK THROUGH A THICK MAZE OF FOLDERS TO TRY AND FIND WHAT I'M LOOKING FOR. ![]() -- ColorStruck Posted via http://www.vistaheads.com |
| | #2 (permalink) | ||||||||||||
| Guest
Posts: n/a
| Re: After reinstalling Vista, cannot use Backup wizard to restore files Posting in all caps makes for hard reading, is considered shouting, and may be ignored by many "ColorStruck" <ColorStruck.35rvop@xxxxxx-mx.forums.vistaheads.com> wrote in message news:ColorStruck.35rvop@xxxxxx-mx.forums.vistaheads.com...
| Guest
Posts: n/a
| Re: After reinstalling Vista, cannot use Backup wizard to restore files I don't know what you're talking about, I did not post in all caps. I'm looking right at my original post right now (not the one you've quoted in your reply) and I clearly did not post in all caps, I posted in Comic Sans font, no caps. -- ColorStruck Posted via http://www.vistaheads.com |
| | #4 (permalink) | ||||||||||||
| Guest
Posts: n/a
| Re: After reinstalling Vista, cannot use Backup wizard to restore files Its all caps. "ColorStruck" <ColorStruck.35rzwa@xxxxxx-mx.forums.vistaheads.com> wrote in message news:ColorStruck.35rzwa@xxxxxx-mx.forums.vistaheads.com...
| | #6 (permalink) | ||||||||||||
| Guest
Posts: n/a
| Re: After reinstalling Vista, cannot use Backup wizard to restore files Check your drivers. Did you also reinstall/update your drivers ? "67walkon" <guest@xxxxxx-email.com> wrote in message news:1801aaa2d11dfdaeba3810e93eb2fa8f@xxxxxx-gateway.com...
| | #7 (permalink) |
| Newbie ![]() Join Date: May 2008 vista home premium 32 bit
Location: Florida | Re: After reinstalling Vista, cannot use Backup wizard to restore files Actually, I have discovered that all the old files are on my c drive under "windows.old". The problem with the Seagate external HD is a Vista issue. After my reinstall, I can physically disconnect the external drive, wait a bit, plug it back and Vista recognizes it. HOwever, next time Vista is started up, it won't recognize it. |
| | #8 (permalink) |
| Senior Member ![]() ![]() ![]() ![]() Join Date: Apr 2008 Home premium 32 bit
Location: Canada | Re: After reinstalling Vista, cannot use Backup wizard to restore files Like I said earlier, re-install all your drivers. It has to be done after reinstalling Vista. |
| | #9 (permalink) |
Location: Florida | Re: After reinstalling Vista, cannot use Backup wizard to restore files Vista has never correctly recognized the Seagate drive. After the re-install, Vista sometimes recognizes it as an USB device and it works fine. Other times, it doesn't recognize it. Very confusing. |
| | #10 (permalink) |
| Newbie ![]() Join Date: Jun 2008 Vista Ultimate
| Re: After reinstalling Vista, cannot use Backup wizard to restore files Hello Friends, I have the same problem. I re-installed Vista Ultimate after it crashed and won't reboot. I got the same error message colorstruck got, and at first I thought maybe the drivers for the WD My Book HDD where the backups reside wasn't installed. So I went to my computer and looked all the six HDD in the system were showing that would mean that vista did install the Drivers. So what gives, why can't I restore my files from the backup? |
| Display Modes | |
| Restoring files from backup and restore after reinstalling vista | Chas | Vista account administration | 1 | 04-06-2008 10:38 PM |
| After clean install of Vista, can't use Backup wizard to restore f | Susan | Vista General | 4 | 03-04-2008 11:55 PM |
| Restore Wizard Doesn't Recognize Backup Set? | NM | Vista General | 2 | 10-21-2007 06:52 AM |
| best backup software for Vista Home Ultimate that will allow me toselect files and folders to backup and restore | Lisa Hetherington | Vista performance & maintenance | 6 | 10-20-2007 08:29 PM |
| Vista RC1-Restore Files from XP Backup? | OneDave | Vista General | 3 | 10-12-2006 05:27 PM |
