Vista - How do I change audio settings???
Old 05-22-2008   #1 (permalink)
CherryPearl23
Here is the problem, I purchased a headphone w/mic and am unable to use them
because my Abit IL9 Pro utilize the HD 7.1 CH Audio while my Cooler Master
Elite 330 case front audio connector utilize the AC7 audio. I thought I
could bypass this by trying to connect the headphones to the back audio
ports. Windows Vista Home Premium would not recongize the headphones. When
I checked the settings in sound, it list headphone connection as front port
only and it would not let me alter the setting to back port. Is there anyway
that I can change headphone setting to back audio instead of the front audio?
audio settings Sound & Audio
Column Settings in Windows Live Mail Folders - change one, change Live Mail
Where are the advanced audio settings? Vista General
NIC settings will not change Vista networking & sharing
Can't change my TCP/IP settings Vista networking & sharing
