Vista Tutorial - Gateway GM5626 and IDT High Definition Audio Drivers -- Issue
Old 05-23-2008   #1 (permalink)
leo17434
Guest
I recently purchased a Gateway Desktop. When the machine goes into sleep
mode, the sound goes away after it starts up again. (No Audio Device
Installed.) WHen I reboot, it is fine.
A similar occurence happens when I cold boot the machine many hours after a
complete shutdown.
I have updated the drivers to the latest available from Intel. But, nothing
solves the problem.
Gateway recommends that I "restore to the factory settings;" i.e. go back to
the beginning which had the same symptoms.
Any ideas?
High Definition Audio Driver Vista hardware & devices
IDT - Audio - IDT High Definition Audio CODEC Vista General
High Definition Audio Controller Drivers
'Sigma Tel High Definition Audio Vista General
Internal High Definition Audio Bus Vista hardware & devices
