Emergency! Please Help!
  1. #1
    Andrei Guest
    Well, it all started when i wanted to change Vista to XP. The setup could not
    find my Hard Drive and my friend ran some Linux thing on it and deleted my
    old harddrive and setup a new one, well, nothing worked afterwards at all.
    Now when i try to do the System recovery to factory standart, nothing
    happens. Maybe I am pressing the wrong button at startup, does anyone know
    what it is? I have A Toshiba, satellite A200 or something like that. Anyaway,
    is there aw way to get my computer working again? I don't have a Vista Setup
    disk, because the computer came with it and i can't create a system recovery
    disk. because, well, my computer doesn't even load up anymore. Please Help
  2. #2
    Nonny Guest
    Re: Emergency! Please Help!
    On Sat, 24 May 2008 19:04:00 -0700, Andrei
    Sounds like it's time to get your "friend" back at the keyboard.
  3. #3
    Carey Frisch [MVP] Guest
    Contact Toshiba support for assistance.
    How to Replace Lost, Broken, or Missing Microsoft Software or Hardware
    http://support.microsoft.com/kb/326246/en-gb
    Carey Frisch
    Microsoft MVP
    Windows Desktop Experience -
    Windows Vista Enthusiast
    "Andrei" <Andrei@xxxxxx> wrote in message news:1836FA94-CA23-48F5-8F1B-FF24E69DB6D6@xxxxxx
  4. #4
    Andrei Guest
    I don't think there will be anything he can do, he tried to restore my HD,
    but failed miserably... isn't there any way to get my computer to at least
    it's "before deletion stage" I don't mind losing drivers or programs, they
    can all be recovered after, but i need my PC...
  5. #5
    Nonny Guest
    On Sat, 24 May 2008 19:48:00 -0700, Andrei
    Not without a CD and a correct key for that CD.
  6. #6
    Nonny Guest
    On Sun, 25 May 2008 07:24:55 +0100, Gordon
    >Put in the Recovery CD into the DVD drive, restart the machine. As it
    >starts, press F12 until it tells you to choose the boot location. Then
    >choose the CDROM drive.
    <cough> He clearly indicated that he doesn't HAVE one.
  7. #7
    DL Guest
    You need to contact Toshiba direct to obtain the recovery cd's.
    Without the recovery disks your Toshiba is functioning as a paperweight.
    Your 'friend' probably destroyed the recovery partition that was on the hard
    disk.
    When you obtain a new PC read the book that came with it. In it you were
    probably instructed on the method of creating the recovery cd/dvd's.
    Your attempt at installing winxp failed because your hard drive is a sata
    drive and requires a particular method of setting up in order to install
    winxp.
    news:7B1D392C-5F6D-404E-A519-8A78402F6B7F@xxxxxx
  8. #8
    Nonny Guest
    On Sun, 25 May 2008 09:56:36 +0100, Gordon
    >One what? Recovery CD or CDROM drive?
    http://preview.tinyurl.com/6z8gtb
  9. #9
    Andrei Guest
    Well, everybody thanks for your advice, I especially thank Nonny, your advice
    about making my friend get back to the keyboard helped. My computer works
    now! and i have XP! Again thank you everyone.
Emergency! Please Help! problems?
Emergency!!! chaosrealm93 General Discussion 14 13 Sep 2010
Solved Emergency help! Salil999 System Security 4 03 Jan 2010
Solved Help now please emergency !!!!! dz11re General Discussion 8 07 Aug 2009
emergency please help jockpsychic Vista General 2 09 Jul 2009
Emergency!!! Cherrygar Vista music pictures video 6 01 Jul 2007
