Vista - Help me….my hard disk is damaged!!!
Old 05-26-2008   #1 (permalink)
Vista Ultimate x64
Hi everyone , I am employed as a manager in a firm. I have a problem that I had like to talk about. My system was working fine the other day, but while copying a file by nero….the system hanged and I had to restart it. But I got a disk boot failure error. Then , I tried to run a windows xp installation CD, but that is also showing some error message during installation and the installation fails.I did check the bios settings and the disk fails to show…and had it checked on another system also…but bios cannot detect the hard disk.I think the disk is damaged or something like that.The disk has important data from my company’s point of view…..that I need to recover.
Please let me know if there are any ways to get my data back from this disk!!!!
Old 05-26-2008   #2 (permalink)
Nonny
Re: Help me….my hard disk is damaged!!!
On Sun, 25 May 2008 23:04:54 -0500, rodger212
>this disk!!!!
Doesn't sound like it. At least not by normal means. Since two
different systems can't see the disk, it's no doubt dead.
It's possible that some company out there might be able handle the job
- and that would charge a horrendous price to do it.
Old 05-26-2008   #3 (permalink)
Colin Barnhorst
Re: Help me..my hard disk is damaged!!!
Can you mount the drive in an external enclosure and use another computer
and some recovery software like OnTrack's to recover the data? You need to
quit trying to access the drive until you can attempt the recovery.
http://www.ontrackdatarecovery.com/d...very-software/
"rodger212" <guest@xxxxxx-email.com> wrote in message
news:823ecd30c72e6dfbf143f86f9d92cbc6@xxxxxx-gateway.com...
> but while copying a file by nero..the system hanged and I had to restart
> and the disk fails to show.and had it checked on another system also.but
> something like that.The disk has important data from my company's point
> of view...that I need to recover.
> this disk!!!!
> rodger212
Old 05-26-2008   #4 (permalink)
Mick Murphy
RE: Help me….my hard disk is damaged!!!
Google it, and download a Knoppix Live CD. It is a compressed 2Gig, down to
700 MBs, and is an ISO Image.
Burn it, and make a bootable CD. Reboot with it.
It does not install on your Hard drive, but runs from CD, using your RAM and
Graphics.
It can find DATA on your HD; copy DATA to a flash drive.
Mick Murphy - Qld - Australia
> this disk!!!!
> rodger212
Old 05-26-2008   #5 (permalink)
Richard G. Harper
If there is essential data on there that must be recovered, the first thing
to do is heed the following advice:
QUIT PICKING AT IT, YOU WILL ONLY MAKE IT WORSE!
Any attempt to recover data from the drive could wind up permanently making
it unrecoverable by any means including professional recovery. It may
already be too late since you've already tried to install and write data to
the disc.
A professional drive recovery service may be able to recover the data but it
will be very expensive and will take some time. Google "hard drive
recovery" for a number of companies that offer this service.
Richard G. Harper [MVP Shell/User] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
> this disk!!!!
> rodger212
Old 05-26-2008   #6 (permalink)
DL
A business with no backup stratergy in place!?
The business is likely to fail after such a failure/loss of data
> this disk!!!!
> rodger212
Old 05-26-2008   #7 (permalink)
propman
> this disk!!!!
Check the manufacturer of your hard drive's web site....some companies
provide a low-level test program you can download.
Old 05-26-2008   #8 (permalink)
Colin Barnhorst
Low level test programs are usually destructive of data on the drive. The
OP needs to recover data, not test the drive. He already knows the drive is
defective. He needs recovery ideas at this point.
"propman" <propman@xxxxxx> wrote in message
news:a9z_j.5151$KB3.1889@xxxxxx
>> this disk!!!!
Old 05-26-2008   #9 (permalink)
propman
Low level as in "checking out the integrity of the drive" not low level
as "reformatting the drive".....the test programs from the hard drive
manufacturers perform non-destructive testing. Low level testing and
low level formating are two different issues. :-)
Colin Barnhorst wrote:
> The OP needs to recover data, not test the drive. He already knows the
> drive is defective. He needs recovery ideas at this point.
>>> this disk!!!!
Old 05-26-2008   #10 (permalink)
Vista x64 Ultimate
On-Track is the best at data recovery. It can be $1000+. I would try putting the drive in another computer as a slave. See if you can access the data. Don't low level test it. It can delete data if you don't know how to do it non-destructive. I would try error checking the drive or see if Acronis can image the files to a new drive.
Windows - No Disk error after installing an external hard disk Vista hardware & devices
Is my hard drive damaged? Drivers
USB hard disk error: "You need to format the disk in drive F: ..." Vista hardware & devices
hard disk General Discussion
New 2nd Hard Disk -visible in Disk Management - but NOT in Explorer/Computer Vista hardware & devices
