I use a Jabra BT125 both for my phone and for day-to-day audio so that I can
listen to internet radio programs and youtube etc without disturbing my
office mates.
Under my fist Vista install this worked great on my Sager NP9262 (BT is
Cambridge Silicon Radio / Microsoft driver) much better than my previous
Dell. Specifically it reconnected when I turn my headset on/off and did not
require re-pairing or restarting applications using audio devices (I think
that means the Microsoft driver doesn't destroy the audio device when the
paired device goes offline, allowing reconnect to work and not lose
functionality).
However under SP1 I've noticed a degraded experience. My device does not
always reconnect properly and I have to de-select the Headset service and
re-select it to receive audio. This removes the audio device requiring
applications to restart and it's a manual process to toggle the Headset
service.
I noticed under SP1 when pairing Vista defaulted to a "Telephony" service.
De-selecting that service before using the Headset service slightly improved
its reliability, but my experience still isn't as good as it was before SP1.
This post is a suggestion for Microsoft, and Microsoft responds to the
suggestions with the most votes. To vote for this suggestion, click the "I
Agree" button in the message pane. If you do not see the button, follow this
link to open the suggestion in the Microsoft Web-based Newsreader and then
click "I Agree" in the message pane.
http://windowshelp.microsoft.com/com...rdware_devices
