Vista Tutorial - audio device help
Old 06-01-2008   #1 (permalink)
A-Nightmare
Guest
audio device help
whenever you plug your headphones or microphone or speakers into any of the
jacks on your PC, it comes up in the little box and asks you what you plugged
into the jack. i accidentally unchecked something and now whenever i plug
things in it wont detect anything in those sound device sockets at the back,
how do i turn the auto detecting thing back on?
Old 06-01-2008   #2 (permalink)
Nonny
Guest
Re: audio device help
On Sun, 1 Jun 2008 17:12:00 -0700, A-Nightmare
>into the jack.
No it doesn't. Maybe when YOU do it, but not when I do it.
Old 06-01-2008   #3 (permalink)
V Green
Guest
"Nonny" <nonnymoose@xxxxxx> wrote in message
news:koh644h2smldnr26154fk398q3qqsfqguc@xxxxxx
> >into the jack.
My, my. Aren't WE the nit-picking jagoff...
Old 06-02-2008   #4 (permalink)
Mick Murphy
Guest
RE: audio device help
Do a System Restore back to when it worked.
If using Norton; disable it 1st.
Start>Programs>Accessories>System Tools>System Restore.
Mick Murphy - Qld - Australia
Old 06-02-2008   #5 (permalink)
Charlie Tame
Guest
This behavior is likely to depend on your hardware and not all Vista
installations will do it, so assuming your sound devices are on the
motherboard then see if you can find anything on the makers' website. If
you do have a separate sound card then look on their website. My guess
would be that you will find an auto sense setting in the sound devices
properties, but it is just a guess.
Old 06-02-2008   #6 (permalink)
A-Nightmare
Guest
Cheers i did a system restore and it fixed it, dunno what i touched to mess
it up though.
Sp1 PnP Audio Device - 0 sound Sound & Audio
audio device not installed Vista music pictures video
Cannot set default audio device Vista hardware & devices
no audio device available Vista installation & setup
Multimedia Audio Device Vista General
