| | SigmaTel High Definition Audio CODEC Hello! Possible bug follows: I just recently installed RC1 and it was pretty smooth--except for the sound. While it runs mostly out of the box and I can not record anything using my microphone. At first it used some generic driver (Microsoft High Defintion Audio.. something like that) and after fiddling with it I think I was able to get it to use the updated driver from Windows Update to stick (did a Roll Back and after refreshing a couple of times it seemingly went back to the SigmaTel driver). Well sure its using the new one (I hope >_>) but nothing shows up Recording section. Somehow no audio devices are installed. Any suggestions? General Computer Specs: Gateway 840GM; Intel 945G (intergrated sound) |
| | RE: SigmaTel High Definition Audio CODEC Sorry about the double (err triple) posts... it said that it errored out and I assumed it was my bad internet connection. |
| | Re: SigmaTel High Definition Audio CODEC David, This may not be on mark;but as I'm on a Dell;my soundcard is Sigmatel; Driver works great!! Jeff "David E" <DavidE@discussions.microsoft.com> wrote in message news:251FAB20-C383-49AA-9971-B30AF2ED5A40@microsoft.com... > Sorry about the double (err triple) posts... it said that it errored out > and > I assumed it was my bad internet connection. |
| SigmaTel High Definition Audio Codec 64bit Driver Needed | Drivers | |||
| SigmaTel High Definition Audio - problem | Vista hardware & devices | |||
| SigmaTel High Definition Audio Codec | Vista hardware & devices | |||
| SigmaTel High Definition Audio CODEC | Vista General | |||
