| | Problem with playback of burned DVD using Media Center I burned a dvd-r from home video using Studio 11. The DVD will play on a DVD Player but will not play from my computer. Help from Studio 11 indicates that Vista has a DVD decoder on it so the dvd should play using Windows media Center. Any Suggestions on what could be done to enable computer playback. BTW, I know the drive works since I play other DVD's on it. |
| | RE: Problem with playback of burned DVD using Media Center Hi Campheel, Since the DVD plays on a DVD player, that indicates that the DVD is working. The most probable cause is that you haven't got the necessary codec installed, or that the codec is corrupted. The solution in this case would be to locate a copy of the codec and reinstall it. However, are you able to see the contents of the DVD on your computer? I am not familiar with Studio 11, but can you play the DVD through that? When you burned the DVD, did you finalize and close it? In some cases, a DVD will play on a DVD player but not a computer because of the difference in the way it is decoded. With a DVD player, the decoder is hardware based as opposed to software based in a computer. Dwarf "Campheel" wrote: Quote: > I burned a dvd-r from home video using Studio 11. The DVD will play on a DVD > Player but will not play from my computer. Help from Studio 11 indicates > that Vista has a DVD decoder on it so the dvd should play using Windows media > Center. Any Suggestions on what could be done to enable computer playback. > > BTW, I know the drive works since I play other DVD's on it. |
| | RE: Problem with playback of burned DVD using Media Center I don't know what codec is or where to locate it to install it. I can see the contents on Windows Explorer but can't play from there. I did finalize and close it. Any other suggestions or instructions on "codec"? Thanks "Dwarf" wrote: Quote: > Hi Campheel, > > Since the DVD plays on a DVD player, that indicates that the DVD is working. > The most probable cause is that you haven't got the necessary codec > installed, or that the codec is corrupted. The solution in this case would be > to locate a copy of the codec and reinstall it. However, are you able to see > the contents of the DVD on your computer? I am not familiar with Studio 11, > but can you play the DVD through that? When you burned the DVD, did you > finalize and close it? In some cases, a DVD will play on a DVD player but not > a computer because of the difference in the way it is decoded. With a DVD > player, the decoder is hardware based as opposed to software based in a > computer. > Dwarf > > "Campheel" wrote: > Quote: > > I burned a dvd-r from home video using Studio 11. The DVD will play on a DVD > > Player but will not play from my computer. Help from Studio 11 indicates > > that Vista has a DVD decoder on it so the dvd should play using Windows media > > Center. Any Suggestions on what could be done to enable computer playback. > > > > BTW, I know the drive works since I play other DVD's on it. |
| dvd playback choppy in media center | Media Center | |||
| BluerRay Playback in Media Center | Media Center | |||
| Media Center TV Playback | Vista music pictures video | |||
| problem with audio during playback of video burned to disc | Vista General | |||
| Vista Ultimate Media Center burned DVD plays upside down and backwards | Vista music pictures video | |||
