Vista - Leadtek tv2000xp expert problem in WMC
Old 06-20-2008   #1 (permalink)
nolan md
hello... I am running Vista Home Premium and would like to use Windows Media
Center to run my tv tuner. I installed a "Leadtek tv2000xp expert" and it is
working properly using it's proprietary software, Winfast PVR2. If I try to
set up WMC to use it, it says that ther is no tv tuner installed in the
computer..
i would great appreciate any help in this matter.
Old 06-20-2008   #2 (permalink)
Curious
Re: Leadtek tv2000xp expert problem in WMC
Your tuner uses software encoding and does not have support for Media
Center2005 or Vista MC it is only supported using its own software.
http://www.leadtek.com/eng/tv_tuner/...lineid=6&act=2
"nolan md" <nolanmd@xxxxxx> wrote in message
news:17F31750-0A32-48D5-9AC6-64E81F34E9F6@xxxxxx
> Media
> is
> to
> computer..
Old 06-22-2008   #3 (permalink)
nolan md
Does it mean then that there is no way to interface it with the media center?
Can you recommend a tv tuner card that works with vista MC? thanks.
> > Media
> > is
> > to
> > computer..
Old 06-22-2008   #4 (permalink)
wayneP
nolanmd,
If you want to stick with Leadtek look here:
http://www.newegg.com/Product/Produc...82E16815122008
wayne
news:1B98785C-A340-40A4-B141-95951EC86A90@xxxxxx
> center?
>> > Media
>> > it
>> > is
>> > try
>> > to
>> > computer..
Old 06-22-2008   #5 (permalink)
Curious
You may want to get one of the newer MC compatible combo analog and OTA ATSC
digital cards such as a Hauppauge 1600 or 1800 or an Avernedia combo PCI
card instead of just an analog card
> center?
>> > Media
>> > it
>> > is
>> > try
>> > to
>> > computer..
Leadtek TV2000 XP Expert sound problem Media Center
To Others With More Than 2GB of Memory And A WinFast TV2000XP Expert/WinFast PVR2 Graphic cards
same problem as last time (leadtek dtv2000H tv tuner) Vista hardware & devices
Leadtek WinFast DTV Dongle USB2 Driver Problem Vista General
TV2000XP Expert Vista hardware & devices
