Vista - Wireless USB and/or PC Cards that work with Vista RC1
Old 09-11-2006   #1 (permalink)
=?Utf-8?B?QnJlbnQ=?=
My Dell D800 internal Wireless (Intel 2200BG) doesn't work with Vista and I
am looking for USB or PC Card solution that will work. All help is
appreciated!!
Thank you,
Brent
Old 09-11-2006   #2 (permalink)
=?Utf-8?B?UmlkZXI1NTEy?=
RE: Wireless USB and/or PC Cards that work with Vista RC1
Hi Brent
I'm using a Belkin 54G USB adapter, F5D7050uk ver4000, and it's working fine
in RC1 with the drivers from CD with WPA2 encryption.
Don't know about earlier versions of the 7050 though.
Hope this helps
Rider5512
"Brent" wrote:
> Hi,
> appreciated!!
> Thank you,
> Brent
Old 09-12-2006   #3 (permalink)
Hi Rider5512,
I got the F5D7050 but unfortunately it didn't work for me. I tried this
Belkin Wireless USB, a Linksys USB and a D-Link PC Card and none worked. The
internal Dell D-800 2200BG works ok with XP but wireless just doesn't want to
work on this computer with Vista.
Thank you for sharing!
Brent
"Rider5512" wrote:
> Hi Brent
> Hope this helps
> Rider5512
> "Brent" wrote:
> > Hi,
> > appreciated!!
> > Thank you,
> > Brent
Re: Vista Does Not Work With Either Network Cards Vista networking & sharing
RE: Vista Does Not Work With Either Network Cards Vista networking & sharing
do any TV tuner cards actually work in Vista? Vista music pictures video
Vista and memory cards, do they work ? Vista hardware & devices
Wireless cards don't work with WEP on VISTA Vista networking & sharing
