Vista - problem wit my vista ulti sp1 32
Old 06-29-2008   #1 (permalink)
Halu
after i format my pc from windows xp and new installation of vista sp1 32, my
windows cant start up after installing forceware for my 8400gs(version 163.71
i think). is that might be that forceware do not compatible with vista
sp1???i also try restore that windows to earlier point and try intall newer
version of forceware,175.19, the problem still not solve..my windows still
cant start up after restart from installing forceware..any idea y??
Old 06-29-2008   #2 (permalink)
Charlie Tame
Re: problem wit my vista ulti sp1 32
Can you get it to start at all? What about safe mode?
What machine is it, or what motherboard if it's one you built.
If you can't get into safe mode then you probably can't easily remove
any drivers.
Old 06-30-2008   #3 (permalink)
Halu
i use gigabyte 945gcmx s2..i can go in safemode..what driver need to
remove???i can't start up exactly after install forceware driver..
> any drivers.
Old 06-30-2008   #4 (permalink)
Charlie Tame
>> any drivers.
Well it has been said that you should remove old NVidia drivers before
installing new. Also only install with a clean system - that means just
after rebooting.
I think your Gigabyte has NVidia drivers as well, check their website
and let the auto download thing pick drivers for the motherboard.
Suggest do that before the video card drivers
Download both packages to the desktop or some easy to find place.
Reboot. Install Gigabyte drivers (If that is what they are). Reboot.
Install Video drivers. Reboot.
It is not safe to try letting these things install automatically in my
experience.
Old 06-30-2008   #5 (permalink)
Halu
it meant that i also need to install the vga driver for my motherboard??even
though i connect my display with my nvdia???
> >> any drivers.
> after rebooting.
> experience.
Old 06-30-2008   #6 (permalink)
Colin Barnhorst
No.
"Halu" <Halu@xxxxxx> wrote in message
newsD6E7908-E989-46D3-ACBB-18C9F43DDD7F@xxxxxx
> motherboard??even
>> >>> sp1 32, my
>> >>> vista
>> >>> newer
>> >>> still
>> >> any drivers.
>> after rebooting.
>> experience.
TOP: C0000218 {Registry File Failure): how to fix it in Vista Ulti Vista installation & setup
Vista Ulti 64 volume mixer has been deleted Drivers
unattended vista ulti x32 installation probs!!! Vista installation & setup
How many times can we activate Vista Ulti til it tell us to call i Vista installation & setup
Dell GX520 Opt-Upgrade to Vista Ulti-Cannot Log on to DC Win2003 S Vista networking & sharing
