Vista - multiple hard drives problem
Old 06-29-2008   #1 (permalink)
taylorstapleton
okay so i just built this new computer, and i installed two 250 gig hard
drives. the bios recognize both drives just fine but windows is not. it only
lists me as having one C: drive with 250 gig and the other one is not listed
at all. is there some setting in windows that i need to enable?
any help is greatly appreciated
Old 06-29-2008   #2 (permalink)
PvdG42
Re: multiple hard drives problem
"taylorstapleton" <taylorstapleton@xxxxxx> wrote in
message news:F100ECEB-E942-4844-BAF6-373190A75BBC@xxxxxx
> only
> listed
Is the second drive partitioned and formatted? The process of installing
your OS took care of that on the OS drive, but before programs like Windows
Explorer will "see" the second drive, it must be partitioned and formatted.
Go into Control Panel -> Administrative Tools -> Computer Management -> Disk
Management and check for the second drive. If it's there, you can partition
and format it.
Old 06-29-2008   #3 (permalink)
JerryM
Go into your BIOS and be sure the second hard drive is recognized, if not ,
Windows can't see it.
> only
> listed
Old 06-29-2008   #4 (permalink)
Dominic Payer
You need to initialise the disk, partition, format and assign a drive letter
in Disk Management.
In Windows Start type diskmgmt.msc and then hit Enter.
> only
> listed
Old 06-29-2008   #5 (permalink)
JerryM
Thanks, Colin.
Jerry
"Colin Barnhorst" <c.barnhorst@xxxxxx> wrote in message
news:39B55F1D-1B24-4D89-930B-75D5EC6A4B47@xxxxxx
Quote:
> The problem is that they are new drives and he has to inialize the second
> one like PvdG42 says. Everything is hunky dorey. The OP just needs to
> complete normal set up of the drive.
> "JerryM" <jerrym526@xxxxxx> wrote in message
> news:uhK74vi2IHA.416@xxxxxx
>> , Windows can't see it.
<Snip>
Old 06-29-2008   #6 (permalink)
Dustin Harper
You can go to the Control Panel > Administrative Tools > Computer Management
Quote:
> then in the left pane, click Disk Management. If you see the disk in
there, you should be able to right click it and partition it, then format
it.
Then Vista will see it with no problems.
Dustin Harper
dharper@xxxxxx
http://www.vistarip.com | Vista Resource & Information Page
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
> only
> listed
Old 06-29-2008   #7 (permalink)
taylorstapleton
RE: multiple hard drives problem
thanks so much you guys. totally solved my problem.
Problems with multiple hard drives Vista installation & setup
Multiple Hard Drives Vista hardware & devices
Multiple Hard Drives Not Recognized Vista installation & setup
Multiple SATA Hard drives Vista hardware & devices
multiple hard drives Vista hardware & devices
