| | blue screen problem Hi, Having a problem when using the remove hardware safely, this works on everything except the modem,when trying to remove the phone connection I get the safe to remove and get a blue screen when doing so, anyone got any suggestions as to what might be wrong. regards aga |
| | Re: blue screen problem aga151 wrote: Quote: > Hi, > Having a problem when using the remove hardware safely, this works on > everything except the modem,when trying to remove the phone connection I get > the safe to remove and get a blue screen when doing so, anyone got any > suggestions as to what might be wrong. > > regards > > aga First guess would be the driver and the first place to look would be the device's manufacturer's website - or perhaps it has some firmware that can be updated. BSODs can be confusing because sometimes it will look like a hardware fault but be nothing more than a driver, sometimes the opposite is the case. |
| | Re: blue screen problem Hi Charlie, When you say the driver, would I be looking for the modem driver update! yes it only seems to be when it's the phone line is removed. Thanks Regards aga "Charlie Tame" wrote: Quote: > aga151 wrote: Quote: > > Hi, > > Having a problem when using the remove hardware safely, this works on > > everything except the modem,when trying to remove the phone connection I get > > the safe to remove and get a blue screen when doing so, anyone got any > > suggestions as to what might be wrong. > > > > regards > > > > aga > > First guess would be the driver and the first place to look would be the > device's manufacturer's website - or perhaps it has some firmware that > can be updated. > > BSODs can be confusing because sometimes it will look like a hardware > fault but be nothing more than a driver, sometimes the opposite is the case. > |
| Blue screen problem | General Discussion | |||
| Blue Screen Problem | General Discussion | |||
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Blue Screen problem | General Discussion | |||
| Blue screen problem | Vista Games | |||
