br> br> |
| | Thread Tools | Display Modes |
| Junior Member Rep Power: 4 ![]() | Hard drive arm keeps going back&forth My computer is not reading my second HD. It keeps making a clicking sound, when I opened it, the drive arm (actuator) keeps going back & forth. Any suggestions? Thanks in advance roach |
| | #2 (permalink) | ||||||||||||
| Guest | Re: Hard drive arm keeps going back&forth Buy a new drive. By opening the drive not only have you cancelled its warranty if any was active but you have also caused unfiltered air to get into the drive which due to extremely fine particles in the air would cause it not to operate properly even if you could fix the original problem with the drive which is probably due to a part failure on the drive's electronics unit. "roach_779" <guest@xxxxxx-email.com> wrote in message news:0118b5e0042dd97e16b243ff455f3af6@xxxxxx-gateway.com...
My System Specs![]() | |||||||||||||
| | #3 (permalink) | ||||||||||||
| Guest | Re: Hard drive arm keeps going back&forth RIP "roach_779" <guest@xxxxxx-email.com> wrote in message news:0118b5e0042dd97e16b243ff455f3af6@xxxxxx-gateway.com...
| Member Rep Power: 6 ![]() | Re: Hard drive arm keeps going back&forth lol Curious & DL. lol noob |
| Junior Member Rep Power: 4 ![]() | Re: Hard drive arm keeps going back&forth When I opened it, I was hopping it would unjam something...one of my last attempt before I throw the drive away. There are service out there that are able to extract files from HD that gone through a fire, I'm sure HD's platter is resilient enough to survive an open case...though I'm not that desperate to use such service. Last edited by roach_779; 07-06-2008 at 09:20 PM. |
| | #6 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Hard drive arm keeps going back&forth "roach_779" <guest@xxxxxx-email.com> wrote in message news:3c52207135f8bb0b95b68526180f1613@xxxxxx-gateway.com...
A local computer shop can advise you whether or not any data on any of the drives are recoverable. You can also buy very good recovery software from companies like OnTrack. The one thing you MUST do is stop trying to access the drives yourself. Every time you do you lessen the likelihood of any recovery. | ||||||||||||||||||||||||||||||||||||
My System Specs![]() | |||||||||||||||||||||||||||||||||||||
| | #7 (permalink) |
| Junior Member Rep Power: 4 ![]() | Re: Hard drive arm keeps going back&forth I'll check that out...thanks! |
| | #8 (permalink) |
| Guest | Re: Hard drive arm keeps going back&forth I must concur with the others: opening the drive is a seriously bad idea if you want to get any data off it. In one of your posts you said "I'm sure the platter is resilient enough to survive an open case". Well, you're wrong! Did you know that the head flies so close to the disk that even a single particle of tobacco smoke can cause a head crash? OK, so you don't smoke, but the point is that the system is EXCEPTIONALLY sensitive to dust and dirt. I'm not saying you will damage the disk, I'm saying you're greatly increasing the risk of damage. When the data recovery companies open up a disk drive (which they do as a last resort), it's done in clean-room conditions. SteveT |
| Display Modes | |
| How to back up to an internal hard drive with Vista ? | Amoranemix | Vista performance & maintenance | 8 | 07-06-2008 05:31 AM |
| Hard Drive Keeps Spinning Down, Back up again | Sam Casperson | Vista General | 3 | 04-29-2008 03:42 PM |
| Back up to external hard drive failure | Tomen1 | Vista General | 3 | 04-21-2008 07:00 PM |
| windows back up to hard drive | bob 9876 | Vista General | 7 | 08-20-2007 06:19 PM |
| Dead Hard Drive when reverting back to XP | Marty | Vista General | 4 | 02-01-2007 08:17 AM |
