Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Go Back   Vista Forums > Vista Newsgroup Archive > Vista Newsgroups > Vista hardware & devices
Vista - Create disable/enable device shortcut for sound card?
07-14-2008   #1 (permalink)
7 Ultimate x64 : Vista x86 VM
Australia
I recently upgraded my sound card to an Azuentech X-Plosion Cinema (Nice card BTW) which I connect to my receiver via coax. I also connect my Xbox 360 to the receiver via optical.
The dilemma:
Both the coax and optical inputs on my receiver are on the same input (Sat/Cable) which means in order to hear sound from my 360 I must disable the sound card in device manager and then re-enable it once I'm finished with the 360. I was wondering whether it was possible to create a Desktop shortcut to disable/enable my sound card? Just like a virtual ON/OFF button.
I'm also curious if by continually disabling/enabling the sound card, does Vista consider this to be a new hardware installation every time and will trigger the activation issue?
I'm running Vista Ultimate SP1 x86
Any help or ideas appreciated.
07-15-2008   #2 (permalink)
Australia
Re: Create disable/enable device shortcut for sound card?
I'm still curious to know if enabling/disabling a device is considered new hardware?
07-18-2008   #3 (permalink)
Australia
Nobody???
 Create disable/enable device shortcut for sound card? problems?
Similar topics to: Create disable/enable device shortcut for sound card?
Sound Recorder - Enable or Disable Tutorials
If I disable the WIFI card from the device manager, is it truly off? Vista General
How to add sound card as a recording device? Vista General
enable on board sound card Vista music pictures video
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
