Vista - Monitor Resolution and Bit Settings Keep changing
Old 07-16-2008   #1 (permalink)
Byron
Hey guys,
I've been running into a problem recently with my monitor. I have Dell D630
Laptop with Vista Business x32 with a NVidia Quadro NVS 135M. I also have a
triple monitor setup using TripleHead2Go by Matrox. This wasn't a problem
before, but I take my laptop home a lot and bring it back to work. For the
most part, it would keep the resolution (or I would have to make small
adjustments and for that session, the settings would remain even after
locking my computer).
For some reason, my triple monitor keeps going to an 8 bit color scheme. If
I change it back to 32 bit, lock my computer, and log back in, the monitors
will blink and revert back to 8 bit. The only thing I can think of is I
recently hooked up my laptop to my TV to watch some movies, but I've done
that in the past on numerous occasions.
I have tried reinstalling the graphic drivers (tried 3 different times) and
still nothing. I went to another workstation and plugged a different monitor
in and that worked fine. I tried changing the resolution on my 3 monitors to
something smaller. When I lock my machine and log back in, it reverts back
to the old resolution setting as well as going back to 8 bit.
I'm going to try reinstalling the drivers for the TripleHead2Go and see if
that helps.
Are there any registry settings that I can change manually? My guess is
that Vista keeps profiles on certain monitor settings and I'm wondering if
that can be changed manually.
Any help is much appreciated.
Byron
Old 07-16-2008   #2 (permalink)
Byron
RE: Monitor Resolution and Bit Settings Keep changing
Well, I just tried installing the Matrox driver/software and that didn't help
either. The one time on a reboot that I got the resolution to stay, my
desktop settings didn't load.
The only other thing I can try is to bring my laptop back to the monitor I
was using at home, but I really hope there's an option to manually change it.
"Byron" wrote:
Quote:
> Hey guys,
> that helps.
> Byron
Old 07-16-2008   #3 (permalink)
Byron
I just tried updating the graphic drivers through Device Manager (got .inf
files from Dell) and after installing, it then prompted me about how I wanted
to display the monitors (always happens when a new monitor is plugged in). I
thought I was golden, but when I locked/logged in, same problem.
"Byron" wrote:
Quote:
> Hey guys,
> that helps.
> Byron
User Settings Disappearing; Monitor Settings Unstable; Desktop Search Overtakes System; Laptops Unusable Vista General
HELP! Monitor Settings Issues: Can't Alter the Monitor Settings... Vista hardware & devices
Changing Display Settings (Resolution mainly) through Safe Mode Vista General
Changing resolution Vista music pictures video
LCD Monitor loses resolution settings Vista hardware & devices
