| | Epson 1200U problem in Vista Ultimate Hi, my great little Epson 1200U scanner won't install in Vista Ultimate. Epson does not have a driver for Vista. The "fix" that is floating around the Internet (disconnect scanner, download latest XP driver, unzip contents, access properties in the setup.exe progam, check the XP SP2 compatibility box, run setup.exe, plug in scanner, praying to the computer gods) does not work in Ultimate. Vista detects the scanner and starts installing the drivers, but says there is an error installing the drivers because it couldn't find a file. It doesn't say what file it couldn't find. Does anyone have advice, another workaround or ??? I really don't want to have to buy a new scanner...help! |
| Problem with Epson EPL5700 on Vista SP1 | Vista print fax & scan | |||
| Epson Prefection 1200U Scanner | Vista hardware & devices | |||
| Epson c88+ problem with Vista | Vista General | |||
| Scanner EPSON 4990 in vista ultimate 64 seen as GT-800... | Vista print fax & scan | |||
| Epson projector problem with vista | Vista hardware & devices | |||
