| | LifeCam VX3000 problems with MS-Messenger live I installed a LifeCam VX3000 on my Windows Vista SP1 machine which installed just fine and works locally as in viewing, taking pictures and videos. My problem is MS-Messenger Live will not recognize the cam nor will Yahoo messenger. Any thoughts on directions I can take to fix the recognition and inability to stream to the web? Thanks, Kevin |
| | RE: LifeCam VX3000 problems with MS-Messenger live Kevin, Try running the Audio / Video Tuning wizard and Windows Live Messenger. It should be under Tools, then Audio and Video setup. Make sure the VX-3000 is selected. Also, note that not more than one program at a time can get video from the camera. So in order to use it in Messenger, you MUST shut down the LifeCam application first. "Kevin S Gallagher" wrote: Quote: > I installed a LifeCam VX3000 on my Windows Vista SP1 machine which installed > just fine and works locally as in viewing, taking pictures and videos. My > problem is MS-Messenger Live will not recognize the cam nor will Yahoo > messenger. > > > > Any thoughts on directions I can take to fix the recognition and inability > to stream to the web? > > > Thanks, > > Kevin > > > |
| Microsoft LifeCam and Windows Live Messenger | Live Messenger | |||
| LifeCam effects in Live Messenger | Live Messenger | |||
| lifecam vx3000 stops windows from starting | Vista hardware & devices | |||
| trouble installing LifeCam VX3000 | .NET General | |||
| Live Messenger with LifeCam | Vista General | |||
