1.    21 Jul 2008 #1
    zinastar Guest
    no speaker icon in taskbar or system tray
    My icon in the bottom right corner of the speaker for adjusting volume
    disappeared. Why and where did it go? how do I get it back
  2.    21 Jul 2008 #2
    Juan Perez Guest
    Re: no speaker icon in taskbar or system tray
    Hi:
    If you go to Start-->Setting->Control panel ->Sound and Audio Devices you
    will see in device volume a tick for Place Volume icon in the task bar.
    Un Saludo
    Juan Perez
    "zinastar" <zinastar@xxxxxx> wrote in message
    newsA760E2E-1C70-474F-952B-17D0B9E30B76@xxxxxx
  3.    21 Jul 2008 #3
    ista Ultimate x64
    Local Time: 15:45
    You said"if you go to Start-->Setting->Control panel ->Sound and Audio Devices you
    will see in device volume a tick for Place Volume icon in the task bar"
    No, I know this applied in XP, but in Vista 64bit you have instead a "sound" item under Control panel and you cant do as you suggest!
  4.    21 Jul 2008 #4
    Juan Perez Guest
    Hi:
    Sorry, I did not realise this was a Vista newgroup.
    Un Saludo
    Juan Perez
    "richardamery" <guest@xxxxxx-email.com> wrote in message
    news:4db6032557b923f9d7634e52d1a30295@xxxxxx-gateway.com...
    > Devices you
    > richardamery
  5.    21 Jul 2008 #5
    Dominic Payer Guest
    Right click your Start orb and select Properties. In the Notification Area
    tab check the Volume icon in System icons.
  6.    21 Jul 2008 #6
    Texas, USA
    64-bit Windows 10 Pro
    Local Time: 16:45
    usa us oklahoma
    Hi Zinastar,
    This tutorial should be able to help you out.
    Notification Area - System Icons
    Quote Originally Posted by zinastar View Post
  7.    19 Aug 2008 #7
    Vista Home Premium 32bit
    Local Time: 15:45
    Quote Originally Posted by Dominic Payer View Post
    I was having the same problem with sound and network icons. Thanks for your post, it worked great.
  8.    25 Jul 2009 #8
    Vista 64
    Local Time: 17:45
    I tried your fix but the Volume icon is shaded - won't let me check. Any suggestions?
  9.    25 Jul 2009 #9
    Birmingham
    Vista Home Premium SP2 32bit.
    Local Time: 22:45
    uk uk england
    Quote Originally Posted by msilverstein View Post
    Right click the Task bar and untick "Lock the Taskbar".
  10.    25 Jul 2009 #10
    Bill Daggett Guest
    brummyfan <guest@xxxxxx-email.com> wrote:
    >msilverstein;1098630 Wrote:
    >> > Area
    >> > newsA760E2E-1C70-474F-952B-17D0B9E30B76@xxxxxx> > > > >
    >> > > volume
    >> > > > disappeared. Why and where did it go? how do I get it back > > > > > >
    >> Any suggestions?
    HUH?
Page 1 of 2 12 LastLast
Speaker icon in taskbar has a 'x' mark on it
My computer is Acer Aspire AM5621-E5612A that came with Realtek Highdef Audio. Since last week there's been an 'x' mark on the speaker icon in the...
Sound & Audio
taskbar shift and system tray
I'm running Vista Premium. After about 3 hours into my session, my taskbar and everything on it shifts to the left, and the system tray completely...
Vista General
Lost my Speaker Icon on the Taskbar
It's gone...I just booted it up and it's not there anymore. Anyone know where it went? Thanks...
Vista performance & maintenance
RE: Speaker icon missing from sys tray
What does it take for Microsoft to come out with a "patch" to fix the problem with icons disappearing from the notification area? It's obvious from...
Vista music pictures video
Taskbar and System Tray icons
Well. They dont work. All of a sudden. The images are fine. I just cant click on them. (this being the windows currently open and the bottom...
Vista General
speaker icon missing from taskbar
My speaker icon is missing from the taskbar - I am running vista. When I go into the taskbar and start menu properties in the notification area I...
Vista General
Power Icon disappears from System tray taskbar and start menu
The battery power icon seems to disappear at times from the system tray/taskbar. I clicked on the taskbar and start menu properties and tabbed...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
