Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Re: So I have a virus on my home pc and looking for help
Update your Vista Drivers Update Your Drivers Now!!
Closed Thread
Thread Tools Display Modes
Old 07-24-2008   #1 (permalink)
Malke
Guest
mattyrz05 wrote:
Quote:
> Somehow, a trojan downloader virus got onto my pc. I have 2 hdd
> currently. The c: drive has 2 main partitions. a 216 gb section for
> main use that also has vista on it, and the other part i just installed
> vista on. the second hdd is just for game/picture/movie storage. Once i
> completed the install to the g: drive(second part of main hdd) i tried
> formatting the c: drive. it said that windows cannot format this
> partition. Is there a formatting option on the vista reinstall cd(using
> reinstall cd that came with my dell machine)? any help would be greatly
> appreciated.
Your post is a bit hard to understand. Are you asking how to remove the
(unnamed) trojan or how to do a clean install of Vista?
To remove the trojan (possibly, depending on with what your computer is
infected):
Do the preparatory steps here:
http://www.elephantboycomputers.com/...moving_Malware
Then do the specific removal steps here:
http://www.elephantboycomputers.com/...itfraud_Trojan - Smitfraud,
Spyaxe, Spyfalcon
You can also check to see if there are targeted removal steps for your
malware here:
Bleeping Computer removal how-to's -
http://www.bleepingcomputer.com/forums/forum55.html
Not all tools used will work in Vista and you will need to run them
elevated. If you are unable to remove the infection by following the
general steps, register at one of the HijackThis forums as suggested.
To do a clean install of Vista, refer to the manual that came with your Dell
computer to see if you have a "restore to factory condition" or a real
Vista installation DVD.
In either case, you would put the disk into the drive and restart your
computer. At the very first beginning screen, press F12 and choose the
option to boot from the CD/DVD drive.
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
FAQ - http://www.elephantboycomputers.com/#FAQ
Old 07-24-2008   #2 (permalink)
Malke
Guest
Malke wrote:
Addendum - I didn't mean to include the information about removing Spyaxe,
etc. It crept in when I wasn't looking. ;-) The rest of the information is
what I wanted to say to you though.
Malke
MS-MVP
Closed Thread
Display Modes
Got a virus alert on a virus that is over a year old WildEagle System Security 8 08-13-2008 11:40 PM
Help with Virus comphulk System Security 4 07-05-2008 03:30 PM
MSN Virus ? Gabriel Live Messenger 1 02-06-2008 10:11 PM
Need help on home network with recovery from rbot.gen virus denzel Vista networking & sharing 2 01-15-2008 11:55 AM
Avast 4.7.881 Home saved my RC1 today from a virus Sascha Benjamin Jazbec Vista General 4 09-11-2006 05:47 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
