Vista - Need help switching from my Laptop monitor to regular CRT
Old 07-24-2008   #1 (permalink)
Vista home
Hey all, just found these forums so let me just say hi first
I just reinstalled vista on my laptop, whose screen is completely destroyed except for one little corner and i was able to do most of it through using the magnifier. I am having a bit of trouble figuring out how to change my primary monitor to my CRT that is plugged in. Never had this problem with XP. Can anyone help me out?
Thanks,
-Brian
Old 07-24-2008   #2 (permalink)
Nogginsaked
Re: Need help switching from my Laptop monitor to regular CRT
There are several vendors that sell replacement laptop screens at reasonable
prices. They are not difficult to install.
Old 07-24-2008   #3 (permalink)
Vista home
finally got FN+F8 to work. Thanks anyways
Solved Switching FIOS from desktop to laptop Network & Sharing
Dual-monitor, task bar switching monitors for no reason! Vista installation & setup
Primary Monitor switching Vista hardware & devices
LAPTOP monitor Vista performance & maintenance
Dual Monitor with laptop LCD Vista General
