Vista - SD Card Reader not reading device
Old 3 Weeks Ago   #11 (permalink)
smlunatick
Re: SD Card Reader not reading device
On Nov 5, 7:50*pm, bball <bball.417...@newsgroup> wrote:
Quote:
> I think the problem is that the cards are SDHC cards. *Although, I want
> to say that we have imported pics from one of these cards before. *I
> still need to try a regular SD card to see if it'll read it. *I did use
> a card reader for the SDHC card and it worked. *Thank you.
> bball
> bball's Profile:http://forums.techarena.in/members/151445.htm
> View this thread:http://forums.techarena.in/vista-har...es/1009651.htm
It must be noted that the physical size of both the SD and SDHC cards
are the same. It is the internal controls that are different because
the SDHC "squeezes" more storage on the card.
SD cards can be read in SDHC reader but SDHC card can never be read.
Re: Installed Acronis True Image Home 2009 & Card Reader would notinatall - Code 10 "unable to load device driver" -Solution Vista hardware & devices
Flash Memory Card Reader - 16 GB SD Card - Won't Read Vista hardware & devices
Re: Card Reader won't read 2Gb SD card Vista hardware & devices
Re: Card Reader won't read 2Gb SD card Vista account administration
nw8000 internal SD card reader handles every card as read-only Vista hardware & devices
