Vista - SD Card Reader not reading device
Old 07-26-2008   #1 (permalink)
Cesar
I have a Toshiba Satellite P105-S9337 running Vista Home Premium. The laptop
has 1-5 internal card reader.
The reader can read the Memory Stick PRO Duo with no problems. However, it
cannot read the SD Memory card.
I looked under the device manager under SD host adapters and verified that
the SDA Standard Compliant SD Host Controlled has the latest drive.
Does anyone have any insight as to how to fix this problem? Any help would
be greatly appreciated.
Thans,
Old 07-26-2008   #2 (permalink)
Curious
Re: SD Card Reader not reading device
How is the SD memory card formatted? Fat32 is usually the best format to
use for memory cards.
"Cesar" <Cesar@xxxxxx> wrote in message
news:AC546F87-7513-4966-8628-C0ED59229DEF@xxxxxx
>laptop
> it
> would
> Thans,
Old 07-26-2008   #3 (permalink)
Cesar
The problem is when I put my SanDisck 512 mb SD card in the reader, the
laptop does not even show an additional drive (normally e:\drive)
> >laptop
> > it
> > would
> > Thans,
Old 3 Weeks Ago   #4 (permalink)
bball
Hello. My computer has 4 slots for sd cards and such. It was working
one day and now it is no longer reading the card. Autoplay is not
opening when I put in a SD card. I checked the settings for Autoplay
and it is set to Ask me everytime. I looked in the device manager and
there was an exclamation point next to 2 USB mass storage devices. I
uninstalled them and restarted the computer twice. Once I did this and
inserted the card the Autoplay box did appear. I thought the problem
was fixed. I clicked to safely remove the hardware. I tried to insert
the card again and nothing happened. At one point the computer was only
showing 3 devices with removable storage. Now it does show 8. I
clicked Disk E and the computer icon is just spinning and will not open
it. I have no idea what is going on! Can someone please help??
bball
bball's Profile: http://forums.techarena.in/members/151445.htm
View this thread: http://forums.techarena.in/vista-har...es/1009651.htm
Old 3 Weeks Ago   #5 (permalink)
Uwe Sieber
"Safely remove hardware" removes the whole cardreader
and it will come back on next reboot.
For card readers the right choice is "Eject", found
when right clicking the drive.
Uwe
Old 3 Weeks Ago   #6 (permalink)
bball
Uwe Sieber;4677264 Wrote:
Quote:
> bball wrote:
> working
> Autoplay
> and
> I
> and
> problem
> insert
> only
> open
> Uwe
Ok. That's what I thought. When I use my flash drive it would prompt
me to safely remove it. However, I don't think we have ever ejected the
SD card from the computer. Once we were finished with the pictures,
we'd just take it out. Never had a problem before...Now since we've
started using a flash drive with the computer, it seems to messed up.
It doesn't recognize when a SD card is put into the slot. The autoplay
box no longer appears.
How can it work one day and then just stop recognizing the device?
bball
Old 3 Weeks Ago   #7 (permalink)
smlunatick
On Nov 4, 8:03*pm, bball <bball.415...@newsgroup> wrote:
Quote:
> > bball wrote:
Quote:
> > > Hello. *My computer has 4 slots for sd cards and such. *It was
> > working
Quote:
> > > one day and now it is no longer reading the card. *Autoplay is not
> > > opening when I put in a SD card. *I checked the settings for
> > Autoplay
Quote:
> > > and it is set to Ask me everytime. *I looked in the device manager
> > and
> > I
Quote:
> > > uninstalled them and restarted the computer twice. *Once I did this
> > and
Quote:
> > > inserted the card the Autoplay box did appear. *I thought the
> > problem
Quote:
> > > was fixed. *I clicked to safely remove the hardware. *I tried to
> > insert
Quote:
> > > the card again and nothing happened. *At one point the computer was
> > only
Quote:
> > > showing 3 devices with removable storage. *Now it does show 8. *I
> > open
Quote:
> > > it. *I have no idea what is going on! *Can someone please help??
Quote:
> > Uwe
> Ok. *That's what I thought. *When I use my flash drive it would prompt
> me to safely remove it. *However, I don't think we have ever ejected the
> SD card from the computer. *Once we were finished with the pictures,
> we'd just take it out. *Never had a problem before...Now since we've
> It doesn't recognize when a SD card is put into the slot. *The autoplay
> box no longer appears. *
> bball
> bball's Profile:http://forums.techarena.in/members/151445.htm
> View this thread:http://forums.techarena.in/vista-har...es/1009651.htm
Yanking a SD media without either 'ejecting" the card or "Safely
Remove" the reader can cause these type of problems.
As of Autplay not working, there are a lot of things that can go
wrong:
-- XP can not see the card -- damaged card because of my first remark
-- XP's Autoplay can be "screwed" up by other software. You should
try Microsoft's AutoFix.
Old 3 Weeks Ago   #8 (permalink)
bball
Noting seems to be working! The SD cards that I'm trying to get to work
on the computer are 2 - 4GB SDHC cards. So I thought maybe the reader
in the computer was not up to date. I tried to download the update for
Vista but said it was not needed for my system. Then, I remembered that
I've used an 8GB SDHC card about a year ago and it worked just fine. I
was able to load the pictures onto my computer.
What am I suppose to do? Why is nothing working? My XD card works
just fine when it's inserted into the slot in the computer; I don't
understand why these aren't working.
Any fixes, or suggestions would be greatly appreciated!
Thanks
bball
Old 3 Weeks Ago   #9 (permalink)
smlunatick
On Nov 4, 11:00*pm, bball <bball.415...@newsgroup> wrote:
Quote:
> Noting seems to be working! *The SD cards that I'm trying to get to work
> on the computer are 2 - 4GB SDHC cards. *So I thought maybe the reader
> in the computer was not up to date. *I tried to download the update for
> Vista but said it was not needed for my system. *Then, I remembered that
> I've used an 8GB SDHC card about a year ago and it worked just fine. *I
> What am I suppose to do? *Why is nothing working? *My XD card works
> Thanks
> bball
Do you have a "spare" USB port? There are external USB card readers
that are affordable. At least you would see if the "hardware" inside
is the problem.
Old 3 Weeks Ago   #10 (permalink)
bball
I think the problem is that the cards are SDHC cards. Although, I want
to say that we have imported pics from one of these cards before. I
still need to try a regular SD card to see if it'll read it. I did use
a card reader for the SDHC card and it worked. Thank you.
bball
Re: Installed Acronis True Image Home 2009 & Card Reader would notinatall - Code 10 "unable to load device driver" -Solution Vista hardware & devices
Flash Memory Card Reader - 16 GB SD Card - Won't Read Vista hardware & devices
Re: Card Reader won't read 2Gb SD card Vista hardware & devices
Re: Card Reader won't read 2Gb SD card Vista account administration
nw8000 internal SD card reader handles every card as read-only Vista hardware & devices
