| 07-29-2008 | #1 (permalink) |
| | Change/delete system partition after BitLocker removal I installed BitLocker and it's preparation tool left me with new system 1.5Gb partition labeled as S: Since this letter is hardcoded and reserved for data in some software we use, I disabled BitLocker. But partition remaind, marked as System and Active. I cannot change letter or delete this partiton since it is marked System. How can I mark another partiton as System so I could get rid of this one? Any ideas would be greatly appriciated since I don't want to reinstall Vista. Best regards, rp |
| My System Specs |
| 07-29-2008 | #2 (permalink) |
| | Re: Change/delete system partition after BitLocker removal On Tue, 29 Jul 2008 11:54:24 +0200, "robinio" <robinio@xxxxxx> wrote: Quote: >I installed BitLocker and it's preparation tool left me with new system >1.5Gb partition labeled as S: Since this letter is hardcoded and reserved >for data in some software we use, I disabled BitLocker. But partition >remaind, marked as System and Active. > >I cannot change letter or delete this partiton since it is marked System. >How can I mark another partiton as System so I could get rid of this one? Quote: > >Any ideas would be greatly appriciated since I don't want to reinstall >Vista. > >Best regards, >rp |
| My System Specs |
| 07-30-2008 | #3 (permalink) |
| | Re: Change/delete system partition after BitLocker removal Question was how to get rid of this partition or at least change driver letter. Marking another partition as 'active' is not problem, but make another partition 'system' is. And as long as this partition is 'system' Windows cannot change drive letter, delete or merge this partition. I'll try some third party solution (like Partition Manager or something) and then I'll probably have to reinstall. But... Regards, rp "andy" <bogusaddress@xxxxxx> wrote in message news:1c7v84d8e3sckqhp21ajbfjh1ak7imcicv@xxxxxx Quote: > On Tue, 29 Jul 2008 11:54:24 +0200, "robinio" <robinio@xxxxxx> wrote: > Quote: >>I installed BitLocker and it's preparation tool left me with new system >>1.5Gb partition labeled as S: Since this letter is hardcoded and reserved >>for data in some software we use, I disabled BitLocker. But partition >>remaind, marked as System and Active. >> >>I cannot change letter or delete this partiton since it is marked System. >>How can I mark another partiton as System so I could get rid of this one? > Disk Management, right click on the partition that should be active. > Quote: >> >>Any ideas would be greatly appriciated since I don't want to reinstall >>Vista. >> >>Best regards, >>rp |
| My System Specs |
| 07-30-2008 | #4 (permalink) |
| | Re: Change/delete system partition after BitLocker removal Do you know what make a partition the Windows system partition? 1. It has to be a primary partition. 2. It has to contain the Vista boot manager files. and 3. It has to be marked active, allowing the motherboard bios to boot from that partition. If Windows can be booted from a partition, that partition becomes its system partition. On Wed, 30 Jul 2008 09:38:15 +0200, "robinio" <robinio@xxxxxx> wrote: Quote: >Question was how to get rid of this partition or at least change driver >letter. Marking another partition as 'active' is not problem, but make >another partition 'system' is. And as long as this partition is 'system' >Windows cannot change drive letter, delete or merge this partition. > >I'll try some third party solution (like Partition Manager or something) and >then I'll probably have to reinstall. But... > >Regards, >rp > > >"andy" <bogusaddress@xxxxxx> wrote in message >news:1c7v84d8e3sckqhp21ajbfjh1ak7imcicv@xxxxxx Quote: >> On Tue, 29 Jul 2008 11:54:24 +0200, "robinio" <robinio@xxxxxx> wrote: >> Quote: >>>I installed BitLocker and it's preparation tool left me with new system >>>1.5Gb partition labeled as S: Since this letter is hardcoded and reserved >>>for data in some software we use, I disabled BitLocker. But partition >>>remaind, marked as System and Active. >>> >>>I cannot change letter or delete this partiton since it is marked System. >>>How can I mark another partiton as System so I could get rid of this one? >> Disk Management, right click on the partition that should be active. >> Quote: >>> >>>Any ideas would be greatly appriciated since I don't want to reinstall >>>Vista. >>> >>>Best regards, >>>rp |
| My System Specs |
| Similar topics to: Change/delete system partition after BitLocker removal | ||||
| System partition removal | General Discussion | |||
| Restore bitlocker partition data without correct partition table ? | Vista security | |||
| How can I change my system partition? | Vista General | |||
| Delete Bitlocker Partition? | Vista security | |||
| Enabling BitLocker Drive Encryption with hidden system partition | Vista installation & setup | |||
