Vista - CPU cooler/temps?
Old 07-30-2008   #1 (permalink)
Win7 Ultimate 64bit
CPU cooler/temps?
What CPU cooler are you using and what are your temps?
I'm using a Vigor gaming 92mm Monsoon II and I've been happy with it for over a year but here lately my temps have been above "my" normal.
I've checked my fan speed and all that, so I'm kinda wondering if it might be going bad. I know how that sounds but mine is a Thermal Electric so it's not just a heatsink and fan combo.
Idle 38*
Heavy Load 3DMark06 during 1st CPU test 59*
When I first got it my temps:
Idle 29*
Heavy Load 3DMark06 during 1st CPU test 42*
Old 07-30-2008   #2 (permalink)
Steve Thackery
Re: CPU cooler/temps?
> Idle 38*
59 degrees is on the warm side, but not enough to worry about. It is well
within the operating parameters of the processor.
> Idle 29*
HOWEVER, the fact that is has got higher is most likely caused by dust
build-up on the heatsink and fan. Blow them completely clean with a
compressed air can and a vacuum cleaner.
Also, some heatsink compounds degrade over time. If cleaning doesn't sort
it out, consider removing the heatsink assembly, cleaning all the old
compound off and replacing it with a smear of the best you can afford.
SteveT
Old 07-30-2008   #3 (permalink)
Win7 Ultimate 64bit
Quote  Quote: Originally Posted by Steve Thackery View Post
> Idle 38*
> Idle 29*
SteveT
There is no dust I keep my PC's cleaned out on a quarterly schedule. I've also removed my heatsink and replaced my compound about a week ago and temps are about the same.
Old 07-30-2008   #4 (permalink)
peter
Summer is here its warmer out.. its warmer in your house...its warmer
inside the case...ergo the CPU runs warmer
peter
DISCLAIMER: If you find a posting or message from me
offensive, inappropriate, or disruptive, please ignore it.
If you don't know how to ignore a posting, complain to
me and I will be only too happy to demonstrate... ;-)
"03hdfatboy" <guest@xxxxxx-email.com> wrote in message
news:cb3efd8065afd11500132390d9fdaab9@xxxxxx-gateway.com...
Quote:
> Steve Thackery;790834 Wrote:
Quote:
Quote:
>> > Idle 38*> > >
>> > > Heavy Load 3DMark06 during 1st CPU test 59* > >
>> well
>> > > Idle 29*
>> > > Heavy Load 3DMark06 during 1st CPU test 42* > >
>> dust
>> sort
>> afford.
>> SteveT
> 03hdfatboy
> *fatboy*
> *3dmark06= 16923*
> http://valid.x86-secret.com/show_oc.php?id=382277
> http://www.techpowerup.com/gpuz/2huxf/
> *-[image:
> http://i61.photobucket.com/albums/h6...=1216732549]-*
Old 07-30-2008   #5 (permalink)
ultimate 64 SP1
im using an arctic cooler pro 775...
cheap as chips but keeps my chip pretty cool...
loads at about 47- 50c at a push...
Old 07-30-2008   #6 (permalink)
Win7 Ultimate 64bit
I'm lookin' at one of these..
Old 07-30-2008   #7 (permalink)
ultimate 64 SP1
Quote  Quote: Originally Posted by 03hdfatboy View Post
that's what i have......
the only downer with this cooler is the push pins ...for some reason they seem far to stiff (i have 2 of them)
but they certainly work well...
Old 07-30-2008   #8 (permalink)
Win7 Ultimate 64bit
Thanks,
I'm also considering this one but it is x2 the price
Old 07-30-2008   #9 (permalink)
ultimate 64 SP1
that's also a nice cooler obviously the full copper construction stacks up the price....
but in all honesty most good HSFs will cool to about the same (give or take a few degrees)
it depends on more variables than just the cooler....i.e.
ambient temps
cable management
case fan configuration
Old 07-30-2008   #10 (permalink)
Dustin Harper
You might clean up and reapply the thermal compound. Your fan usually makes
a noise when it is going bad.
Dustin Harper
dharper@xxxxxx
http://www.vistarip.com | Vista Resource & Information Page
news:248dca793b1ae0dba379ad651ebc4fd2@xxxxxx-gateway.com...
> Idle 38*
> Idle 29*
> 03hdfatboy
> *fatboy*
> *3dmark06= 16923*
> *-[image:
CPU Cooler Overclocking & Cooling
Are these temps right? Overclocking & Cooling
Best cooler for Phenom II Overclocking & Cooling
Best Cooler for Core i7 Overclocking & Cooling
cpu cooler Overclocking & Cooling
