| | SigmaTel High Definition Audio - problem Hi there, I have the sound device "SigmaTel High Definition Audio CODEC" (STAC 92XX C-Major HD Audio) which came with my Dell Dimension 5150. Some times some of the Windows Sounds don't function correctly. They loop (have the broken record effect). The Default Beep (Windows Ding.wav) is one that tends to have this problem when prompted. It also plays slightly delayed, performs like the system is using a lot of system resources for a moment. Appart from this minor issue my sound seems to work fine. I am running a clean install of Windows Vista Home Premium SP1. Driver details: Provider: SigmaTel Date: 12/01/2007 Driver Version: 6.10.0.5343 Anyone tested this on this system? ---------------- This post is a suggestion for Microsoft, and Microsoft responds to the suggestions with the most votes. To vote for this suggestion, click the "I Agree" button in the message pane. If you do not see the button, follow this link to open the suggestion in the Microsoft Web-based Newsreader and then click "I Agree" in the message pane. http://www.microsoft.com/communities...rdware_devices |
| | Re: SigmaTel High Definition Audio - problem Dell finally released a driver for the XPS410 that allowed SP1 to install 6.10.0.5866 dated 1/15/2008 SIGMATEL_STAC_92XX-C-Major-H_A06_R182475.exe I downloaded it on 6/6/2008 Michael "ELW" <ewyatt__delme__@xxxxxx> wrote in message news:g706bs$guv$1@xxxxxx Quote: > > "goorambatman" <goorambatman@xxxxxx> wrote in message > news:AF508D59-0D37-4A80-8B21-4DE2A671A32F@xxxxxx Quote: >> Hi there, I have the sound device "SigmaTel High Definition Audio CODEC" >> (STAC 92XX C-Major HD Audio) which came with my Dell Dimension 5150. >> > upgrade to Vista SP-1, and I had the same problem with audio hiccups. I > did like many others, since Dell doesn't seem interested in giving us an > updated SigmaTel driver: I uninstalled (and deleted files) the SigmaTel > audio drivers using the Device Manager and uninstalled anything to do with > SigmaTel in Programs and Features. Then I rebooted, and Vista installed > Microsoft HD audio drivers and all is well. > > This may work for you; however, I wonder if you have a "service" running > when you have your audio problems. If Vista is in the middle of a defrag > or Windows Defender scan, etc., that may make your audio frizzle a bit. > > Bottom line, you can't go wrong by ridding yourself of SigmaTel and using > the MS driver. At the very least, you can always go back to the Dell site > and reinstall Sigmatel. > > EW > > |
| | Re: SigmaTel High Definition Audio - problem "Michael Walraven" <mexxwalraven@xxxxxx> wrote in message news:F1C53A54-338F-49A4-BA28-8E5872833417@xxxxxx Quote: > Dell finally released a driver for the XPS410 that allowed SP1 to install > 6.10.0.5866 > dated 1/15/2008 > SIGMATEL_STAC_92XX-C-Major-H_A06_R182475.exe I wonder why the 1/15/2008 date if it was recently released. Guess I don't understand these things. |
| SigmaTel High Definition Audio Driver | Vista hardware & devices | |||
| SigmaTel High Definition Audio Codec | Vista hardware & devices | |||
| SigmaTel High Definition Audio CODEC | Vista General | |||
| SigmaTel High Definition Audio CODEC | Vista hardware & devices | |||
