| | Scanner Problem My scanner (CanoScan FB 630U) won't run/install on Vista Premium, incompatible drivers. Although I might get it to work using Vuescan, I'd like to know whether you can get Vista to run in XP mode for incompatible software. My scanning is very infrequent so can't really justify the price for Vuescan. Mickey |
| USB scanner problem | Vista installation & setup | |||
| Problem with Lexmark x2480 scanner | Vista print fax & scan | |||
| Scanner problem with Vista | Vista General | |||
| Epson 4990 Scanner problem | Vista print fax & scan | |||
| scanner problem | Vista General | |||
